586,065 active members*
4,327 visitors online*
Results 1 to 14 of 14
    May 2007
    1026
    Current opinion on RapidTurn?
    I have an 1100 Series 3 I've been very happy with for the past 5 years. Considered the Slant-Pro but just can't justify the $$$ relative to the number of turned parts I do right now, so taking a harder look at the RapidTurn and how good it is generally and for my purposes.
    The largest part I'd want to make is a 2" flange in 6061 that gets turned down to a 25mm shoulder for a bearing slip fit and a 15/16-20 threaded section. So starting with 2.25" stock and turning about 2" of it down to 1". Right now I make this part on the mill by holding the stock vertically in a three-jaw chuck, it's a few thou out of round this way but good enough for my purposes. I thread-mill the threaded section and it works but it's slow and always fun because of how easy it is to snap a $50 thread mill A lot of other parts I'd make would be 1" or less diameter by 1-3" long, typically 6061/360/acetal.
    I also have the ubiquitous Grizzly 10x G0602 lathe which is fine but I regret buying because it uses change gears and belts to adjust speed. I can make good parts on it but the repetitive setups for threading with the change gears are why I make those flanges on the mill. I wish I'd bitten the bullet and gotten one of the 12x lathes, but I didn't feel like dropping twice the money for the small number of turned parts I make.
    I have a full Tormach baby QCTP setup from my old 7x lathe, so I wouldn't need much besides the basic RapidTurn kit, so the cost would be easy to swallow. And I have the 10x for those rare times I need to move metal on larger/longer parts. My hesitation comes from two things:
    - Setup: I don't love the idea of having to set up and tear down the system to make one turned part. My work is prototyping so there's a lot of onesy-twosy stuff and I've continued to invest in quick-change toolholding and workholding to make setup easier. How long does it take people in the real world to change over and get things dialed in OK?
    - Reliability: I've read some grumbling online about the toolpost moving and difficulty making consistent parts. If the story here is that you basically need to treat it like a 7x lathe in terms of rigidity and such, that's fine, I made plenty of good parts on mine. What I don't like is constant tweaking, which is why I decided to not bother trying to CNC my 10x lathe. Though I have considered making a fine feed motor because the worst part of the change gear setup is needing to switch between threading and fine feed to turn a clean shoulder and a threaded section on one part....
    Curious to hear experiences from those who have one. I have watched some of Keen's videos which are both impressive for what he's built and a bit off-putting in terms of the amount of work it seems to have taken to get there. In my experience it's tempting to get a shiny new toy that will make a part slightly faster or nicer but take 5x as much time to learn/set up said toy versus doing something with what I already have. Fun but I am trying to stay focused on my existing projects rather than starting new ones....
    Feb 2018
    17
    Re: Current opinion on RapidTurn?
    I'm not sure if it if it would save you any, but what about cutting the parts from bar stock in the vise and interpolating all the features. You maybe be able to get several parts programmed together on one strip of material. Then make some fixture of soft jaws to flip them over and clean off the back side/waste stock. I have some round parts that are 1.25" OD that I plan to do this with. Set-up and programming is easier (for me) compared to putting the stock i a spindle chuck.
    I guess it would depend on how round you need your diameters to be. For me its not too critical so this should work out.
    I feel like this side of the forums is a little less DIY, but for less than the price of the Rapid Turn you could convert your G0602 to a CNC lathe...
    Feb 2007
    1538
    Hi Sansbury.
    " In my experience it's tempting to get a shiny new toy that will make a part slightly faster or nicer but take 5x as much time to learn/set up said toy versus doing something with what I already have. Fun but I am trying to stay focused on my existing projects rather than starting new ones...."
    Oh yes..very true. There is a lot on your questions and I will resist the temptation to rush out a quick answer.
    Cheers Cliff
    Nov 2016
    151
    Do you already own a manual lathe?
    May 2007
    1026
    Quote Originally Posted by syscore View Post
    Yeah, see original post--Grizzly 10x. That was my mistake, buying something without a QCGB. That makes setting threading up just enough of a PITA that I avoid it unless it's the only solution. And frankly I find manual threading to just be a bit fussier than I like--my thread forms often look slightly off (though they work) and no amount of fussing with the threading dial, infeed angle, tool grind, or anything has made this a foolproof process. I've had good luck making CNC processes that just work once I have the parameters dialed in well.
    Quote Originally Posted by hersh View Post
    <snip>
    Yeah, if I needed to make a bunch of these I'd do that. Milling is round enough for this. It's more that I get just enough parts where I think, "boy, I'd make these faster/nicer if I had a CNC lathe."
    I've considered that but keep flinching. Before I got the 1100 I'd built two router tables and converted a micro-mill, an X2 mill, and a 7x lathe, including making all the parts for the conversions. So I know the drill and actually probably have almost all the parts needed in my storage heap. I learned a lot doing that but I felt like they were all projects that occasionally made parts. With the 1100 I spend 99% of my time working directly on making parts.
    I have been thinking about an electronic lead screw build for the 10x that would be a bolt-on arrangement that kept the manual functionality completely intact. I'm kind of surprised there aren't more projects like that around, but maybe that's a sign that it's either not as easy or not as useful as it seems. Again, it's easy to get distracted by side projects. This is the main project, if anybody cares to dig around my channel I've got video of my 7x CNC hilariously titled "first real part." That was probably the last part I made on the thing, but it worked!
    Feb 2007
    1538
    Not sure if you were asking me, but,
    Today running rapidturn and my manual lathe and thinking about your situation.
    I set up a job in rapidturn I have been doing for years in my manual lathe - I had been putting this off as the job was perfect for a manual lathe - very simple one cut to a stop sort of thing.
    But I had 80 to make and thought I would try it in RT - well it was worth it in short because RT does not get bored or tired. But if you only want to make 1 or 2 parts, I would say most simple parts can be set up more quickly in a manual lathe. if you have DRO tool offsets and quick change toolpost.
    Every job is different and has an optimum machining process. I am installing Slantpro now, and I am sure that will take longer to pay for itself than RT.
    Cheers Cliff
    Sep 2009
    1856
    How much did the Slantpro end up costing Cliff
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Jun 2012
    311
    Quote Originally Posted by sansbury View Post
    ...Right now I make this part on the mill by holding the stock vertically in a three-jaw chuck, it's a few thou out of round this way but good enough for my purposes...
    I'm in a similar situation, occasionally need a CNC lathe and use the "Mill as Lathe" feature. I've never had any accuracy issues though. Turned parts come out round within a few tenths. You got major spindle issues if it can't turn a round part.
    Feb 2007
    1538
    Quote Originally Posted by daniellyall View Post
    Gidday. If you buy one with the turret and gang tooling etc inc freight you are looking at NZ 30K plus gst.
    Cheers Cliff
    May 2007
    1026
    Quote Originally Posted by IMT View Post
    I'm milling the parts with round stock held in a chuck as a vise.
    Jun 2012
    311
    That makes sense then. I misinterpreted what you were saying.
    Mar 2017
    17
    I have turned hundreds of parts with mine and enjoy using it. That being said there are things that are required in my opinion to make it useful.
    You will notice many of us have opted to make gang tooling there is a reason for that. I tried using the stock QTP which for one off and very low volume parts that may be good enough. I did have a terrible time keeping the qtp aligned properly.
    I made a gang tooling setup sort of like user keen on the rapid turn thread built but to be honest that has it's issues also, the biggest of which is the time it takes to remove it and return the mill to normal function. I created another gang tooling
    setup now which took less than a hour to make and can be installed or removed in 30 seconds. I used the original spindle mount, bought a grinder side mount attachment and welded on a t-slot table I bought from little machine shop, this
    has worked fantastic and is extremely flexible.
    Recently I had to turn a run of over 500 parts. I could get two parts per run, had to reset the stock and cycle start again. This took a extreme amount of time and was a very unpleasant amount of work due to having to manually pull and set
    the stock each run. I am soon to have to do a similar run and I have had enough of manually messing around with the collet every cycle. I ran across a youtube video that Bob Roderson, he showed how he adapted a lever operated collet
    closer to his rapidturn. Now that was a neat idea but I saw tormach had a pneumatic collet closer for the slant pro. I have now added a bar puller to my gang setup and adapted a pneumatic collet closer to my rapid turn, no more manually setting
    the stock it will be able to run a full bar through hands free.
    Jun 2012
    311
    Awesome!!! Is the collet closer from Tormach? It looks like the one for the Slant Pro. Or did you source it elsewhere?
    Mar 2017
    17
    I used the tormach kit but it is simply a dunham 5c collet closer and 24 inch drawbar tube.
    To adapt it I used a atlas 10 inch lathe to rough in a 5x 1.5 inch spacer with a bore to fit just around the spindle locknut. I put the spacer on the mill and drilled the bolt pattern for the dunham closer, I drilled another through hole 4 bolt pattern to bolt it to the spindle pulley which I tapped. I mounted the rapid turn backwards on the table, took a light facing cut on the spindle pulley face bolted on the spacer and indicated it in. Took a light cut on the spacer face and bolted on the closer. Put a indicator on the end and tapped the closer into place and bolted it tight. I turned down the drawbar tube to fit through the rapidturn spindle (part way only enough to fit through the rapidturn spindle). I modified the pulley cover buy cutting the hole larger and welding on the solenoid bracket etc.
    I reversed the air lines feeding the closer so that when power is applied it is in the closed position. I run coolant so I just ganged it to my coolant pump for control from the path pilot main screen as well as using the coolant so M9 to open the collet and shut off flood coolant and M8 to close the collet and turn on coolant.
  1. RAPIDTURN VIDEOS
    By keen in forum Tormach Personal CNC Mill
    Last Post: 01-27-2021, 12:03 AM
  2. Anyone part A2 on RapidTurn?
    By kodex in forum Tormach Personal CNC Mill
    Last Post: 03-11-2018, 09:25 PM
  3. RapidTurn and PCNC770
    By kstrauss in forum Tormach Personal CNC Mill
    Last Post: 07-31-2016, 03:57 PM
  4. RapidTurn and Fusion 360
    By mattford1 in forum Tormach Personal CNC Mill
    Last Post: 07-31-2016, 03:35 PM
  5. RapidTurn Order
    Last Post: 07-12-2016, 08:35 PM
