586,067 active members*
5,047 visitors online*
Results 1 to 1 of 1
    Feb 2017
    POWER DRAWBAR HELP NEEDED!
    Can someone suggest a suitable pneumatic air solenoid valve I can use for controlling my single acting air cylinder (spring return)
    I have looked at 3 way 2 position valves would this be suitable for the application? If so any suggestions of any available?
    With regards to the wiring side, say I have a 12v DC air solenoid valve does the attached image look correct for connecting it to a control relay board ? Such as the cnc4pc c15 relay board that I have - https://cnc4pc.com/c15-dual-relay-board.html - also on the air solenoid valves I have been looking at they say 12v DC 3.0w what power supply would you use to power this 12v amps?
    I am looking to control it all through mach3 via the c15 relay board
    Any help will be muchly appreciated
    Attached Thumbnails Attached Thumbnails 84B2D96A-BCE7-419B-B172-5F42600D743B.jpg
  1. My DIY power drawbar for the PM940 CNC VS No air needed
    By rodjava in forum Benchtop Machines
    Last Post: 11-20-2017, 02:49 PM
  2. 440 Power Drawbar
    By tbev in forum Tormach Personal CNC Mill
    Last Post: 02-02-2017, 06:37 AM
  3. 30Taper YCM30 Drawbar or power drawbar options.
    By countryguy in forum Knee Vertical Mills
    Last Post: 12-28-2014, 06:15 AM
  4. My air over oil power drawbar
    By Etced in forum Tormach Personal CNC Mill
    Last Post: 03-17-2011, 09:00 PM
  5. power drawbar now available
    By syil canada in forum Videos
    Last Post: 03-16-2010, 05:52 PM
