586,069 active members*
3,499 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA LCS-15H alarm 3901
Results 1 to 3 of 3
    Jun 2016
    17
    I have problem with okuma ( control:OSP 700L) machine lcs 15H, I have external alarm 3901, which means this fault? How can i view the plc ladder in this control OSP 700L?
    please i need helps.
    Aug 2012
    164
    Re: OKUMA LCS-15H alarm 3901
    I believe that indicates that you have an external alarm; look through your schematic for an external alarm input and then check the signal in check data that corresponds to the input in the schematic; I believe it should be high (on) under normal conditions and off (low) when it is in alarm state. No ladder on the 700L control.
    Apr 2009
    1262
    Typically it means that a device such as a bar feeder or coolant pump, etc. is in a fault condition. Something other than the machine is wrong, thus, external device.
  1. okuma alarm 937
    By RINES in forum Okuma
    Last Post: 06-30-2021, 08:46 PM
  2. OKUMA VAC III ALARM 25 help
    By cnurcanli in forum Okuma
    Last Post: 01-12-2015, 10:13 PM
  3. okuma 609 bdu alarm
    By Brepins in forum Okuma
    Last Post: 12-17-2009, 09:23 AM
  4. OKUMA LNC-8 ALARM!!
    By sullivanmfg in forum CNC Machining Centers
    Last Post: 08-20-2009, 02:12 PM
