Anybody with a post, or at least some programming info for a tosnuc 777 control please respond.
We are purchasing a used toshiba next week, and of course, new programs are required immediately!!
Any help at all greatly appreciated.
Simon.Canada
Simon.Canada
Hello,
I have a machine with a Tosnuc 600 control. Most general G-codes will work the same, but the fixture offsets are called differently, and some other major differences. The guy you need to talk to for all your Toshiba needs is Paul at Dragan Industrial. He is in Canada. You can find him at www.draganindustrial.com or www.tosnuc.com
Other than that, factory support is almost nil. Sorry...
Carl Crawford
www.speed-source.net
Hi Carl,
Could you please send me the Parameter of your Tosnuc 600m?
Hi SIMONB,
Could you please send me the parameter of your Tosnuc 777?
I have a lost parameter Fine Sodick milling with Tosnuc 800D, hope your parameter can help me fix my machine.
Thank a lot.
The 800 is still suppprted by the manufacturer, I suggest you contact Toshiba and have them send you the parameters. Or, cantact your machine manufacturer and get it from them..
CArl C
hello
I have Toshiba milling machine with tosnuc 777.2 control . the model of machin is VMC-55E with 3 axis .
we confront with this alarm. <<Nc 4-14 encoder absolute position abnormal >>
I have changed batteries in encoder for two axes (Y , Z) , And a battery connected to the main board (down battery). However the alarm don’t remove.
and other problem , I don’t have any information about the parameters of the machine . I can see a limited number of Parameter of machine .
How can I access the rest of the parameters?( And explanations of them .)
could every body guide me ?
how can i see all parameter ?
how can i see program num 90000000 about ATC cycle ?
Best regards
