586,036 active members*
3,688 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > Mori seiki mv40 '91, Fanuc MF 4, error EX 1270 Illegal movement
    Sep 2017
    Mori Seiki MV40 '91
    During the tool exchange procedure there was power down. After that the error code "EX 1270 Illegal movement" appeared .
    Control unit is Fanuc MF 4. Mag. Switches KM41 and KM141 on the tool magazine as well as KM31 and KM131 (ATC arm) are checked and are functional.Relay board is functional also..
    The manual movement of tool magazine is possible, anyting else is blocked.
    Please help!
    Sincerely,
    Nenad Sakan
    Re: Mori seiki mv40 '91, Fanuc MF 4, error EX 1270 Illegal movement
    Quote Originally Posted by nsakan View Post
    Mori Seiki MV40 '91
    Please help!
    Sincerely,
    Nenad Sakan
    Hi
    I have the exact same problem,
    please tell me if you find any soulotion
    thanks
    Mori Seiki MV40 '91
    Please help!
    Sincerely,
    Nenad Sakan
    hi
    fanaly i found the soloution
    you should change the 0553 parameter
    all the bits in this parameter should be set as zero
    Mar 2022
    hello
    The same mistake occurred to me on Mori seiki mv-junior.
    When changing tools.
    Fanuc O-M
    if you have a solution, it would mean a lot to me ..
    Thanks,,
  1. Replies: 27
    Last Post: 12-26-2018, 03:58 AM
  2. MORI SEIKI MV40
    By simke55 in forum Mori Seiki Mills
    Last Post: 04-12-2017, 07:50 PM
  3. Mori Seiki mv40 10m pmc par
    By actmach1 in forum CNC Wood Router Project Log
    Last Post: 04-11-2017, 06:52 PM
  4. Mori Seiki MV40 with Fanuc OM-C
    By rai in forum Mori Seiki Mills
    Last Post: 11-03-2015, 04:30 PM
  5. Ladder Diagram for Mori Seiki MV40/Fanuc 6M-B
    By Randy K in forum Mori Seiki Mills
    Last Post: 03-06-2012, 11:21 AM
