586,060 active members*
4,468 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Leadwell Mill - Mitsubishi FCA 50M Controller - ATC Software Issues
    Sep 2006
    8
    Dead battery on a Mitsubishi FCA50M Controller fitted to a Leadwell XYZ style CNC Mill. Have replaced all parameters and subprograms and have the machine 90% working apart from ATC tool selection.
    Program M6 T3 and Z goes to second reference point. Carrousel moves forward and puts tool away but when selecting next tool the carrousel continues to rotate for ever, nether to select any tool. Its as if the controller does not know what tool number the drum is actually on and what tool is in the spindle. The plc input from the tool counter is working so it can count the rotations OK. Before the battery died the tool changer was working OK.
    The only clue I have is the book of parameters that came with the machine denotes :-
    R36 = Tool Code number
    R1954 = Spindle Tool Number
    R1984 = Magazine Tool Number
    At no point can I find or change these R numbers or tell the controller what’s in the spindle or what’s in the magazine.
    Any help on changing these R values or another way to tell the PLC what tools are loaded/spindle/magazine would be much appreciated.
    Thanks Dave
    Re: Leadwell Mill - Mitsubishi FCA 50M Controller - ATC Software Issues
    I too have a leadwell VMC-15 with a meldas 50 controller and have very little information but do have the setup code for this machine. But I do need some manuals maybe Maybe the one that. you have if you do would you be able to coply it for me ge pdf file. And yes i know this a big ask.
    Robert
    Sep 2017
    139
    R parameters can be changed from Diagnosis --> PLC I/F screen
    I have found how to set the R Parameters Meldas M50
    R parameters can be changed from Diagnosis --> PLC I/F screen and the Formate is Address-Data-Mode. The Mode is set to “1” to write the data in.
    Jul 2015
    28
    Quote Originally Posted by bionic-bean View Post
    Thanks Dave
    Hey did you manage to fix this issue?
    Thanks!
  1. GSK Controller 980 TDB. Software issues, PLC not working!
    By AdamCQ in forum Controller & Computer Solutions
    Last Post: 01-09-2018, 06:47 AM
  2. anyone have any issues with UC 300eth controller and software?
    By baxter435 in forum UCCNC Control Software
    Last Post: 11-06-2016, 09:43 AM
  3. Leadwell w/Mitsubishi control won't change tools - help!
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 09-17-2013, 05:06 AM
  4. Mitsubishi meldas3 on leadwell gtc 20
    By jerryinmich57 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-12-2011, 10:57 PM
  5. Running into memory issues Mitsubishi M-V60C - Meldas 300 Controller
    By Josh Lehman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-07-2009, 04:38 PM
