586,521 active members*
3,435 visitors online*
Results 1 to 9 of 9
    Apr 2018
    6
    Unhappy Mach3 Freeze after pressing the go to zero button.
    I just bought a Chinese 3040USB 4 axis CNC. The problem is every time I press the go to zero button the program get FREEZE.
    I cannot click anything. I have to End task the program to use it again. So I asked the seller but they cannot help me at all.
    The mach3 version is 3.043.066 and the controller board is BL-USBMACH.
    I also tried with Win7 x86 x64, Win8 and WinXP but the problem still goes the same.
    I never used a CNC with the usbmach.dll plugin before.
    But I've been using the 6040z which use the NcUsbPod.dll plugin and it works very well.
    Here's the picture and XML file.
    Jun 2010
    4256
    Re: Mach3 Freeze after pressing the go to zero button.
    Does Mach even know where 'zero' is at that stage? I suspect not.
    But having had poor results from a few tests, I LEARNT and do not use the GoToZero button.
    Cheers
    Roger
    15362
    Quote Originally Posted by EaiZtH View Post
    Are you using the real Mach3 with a Mach3 license, or the hacked Chinese copy of Mach3 which does not work for a lot of the normal functions
    Mactec54
    Apr 2018
    6
    I'm afraid it's the Chinese hacked mach3.
    15362
    There will be other functions that don't work as they should also, the only way to solve it is to get the real unhacked software, plus license
    Mactec54
    Jun 2010
    4256
    You do know you can download the real official Mach3 and try it out for FREE?
    Go for the 0.062 version, not the final release of 0.066.
    There is a 500 line limit and there may be one or two functions which do not work, like lathe threading, but those are spelt out.
    Cheers
    Roger
    Apr 2018
    6
    Thank you for the information everyone. I'll try the official one and then report ASAP.
    Be sure to run it in demo mode, and not with the pirated license file.
    Apr 2018
    6
    I try the Mach3 Demo but it not work again. It's like I'm missing something. So I found this BL-UsbMach-V22.dll on the internet. Then I use this instead of UsbMach.dll and it's work!!!
    Thanks everyone again.
    Cheers
  1. Replies: 1
    Last Post: 05-20-2020, 01:56 PM
  2. Can not go to home after pressing RESET button? ????
    By Apples in forum Mach Software (ArtSoft software)
    Last Post: 03-12-2016, 03:00 AM
  3. FP3NC - bosch PC rebooting when pressing "ON" button
    By Alex_Russia in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 02-04-2016, 07:29 PM
  4. Button and cursor freeze
    By gunda in forum Okuma
    Last Post: 07-20-2014, 11:47 PM
  5. laser with MPC 6525 - laser blocks after pressing the START button
    By WendyL in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-27-2013, 07:39 AM
