I am planning on setting up my table in the corner of my shop. But I am not sure of what everyone is doing on clearances. Can anyone shine some light on this..
THanks
THanks
I have mine in the corner and have it as tight as I could make it. I haven't run into an issue with it yet. The couple of times I've needed to do something at the back my 9yr old was happy to jump on top and handle it.
I posted some dimensions of mine ( PRO 4824 ) in an earlier thread about an enclosure.
Let me know if you have any more questions or would like pics.
Hi there,
Check our these specs for Pro 4896
Specs
Work Area:
X: 51" (1295 mm)
Y: 99.5" (2527 mm)
Z: 8" (203 mm) or 12" (304 mm) - minus spoil board thickness
Footprint:
Width: 63" (1600 mm) or 72" (1829 mm) with extended gantry [2]
Length: 112.2" (2850 mm)
Height:
35" (889 mm)
68" (1727 mm)(with optional Leg Kit)
Weight:
483 lbs (219 kg)
616 lbs (279 kg) (with optional Leg Kit)
Based on the size of the corner you mentioned, you can determine how much clearance you'd need for your machine.
Thanks.
