586,068 active members*
3,978 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Plunge End mill to make a Counter Bore in steel?
    Aug 2015
    9
    The attached part requires a 0.194" thru hole with a 0.349" counter bore at a depth of 0.25". The material is steel and I will be using carbide spot drills, drills and end mills.
    My question is, should I drill the thru hole and then peck cycle with an 11/32" End mill (within tolerance), or should I use a 3/16" (.1875) end mill and use a circular milling cycle to bring the counter bore to the correct size? I know plunging with an end mill is usually a bad thing, but I will already have a thru hole so I was hoping I could get away with it.
    I will be holding the part in a 4 axis chuck on a vertical mill (coolant).
    I have almost a 1,000 of these to do and would obviously like to have the quickest program possible but don't want to burn out my tools.
    Thanks!
    Nov 2007
    479
    Re: Plunge End mill to make a Counter Bore in steel?
    If you can drill it with screw machine drill then interpolate the hole with the 3/16 end mill, it would only be 2 tools and probably the quickest. Cam software would be able to tell you the cycle times of any variable you described.
    Feb 2009
    6028
    Back in the olden days, we used a counterbore tool or ground flat bottom end mills, just plunging a standard end mill down a hole is not going to leave a flat bottom..
    Sent from my SM-T813 using Tapatalk
    Dec 2013
    5717
    I avoid plunging with an endmill where possible, but with a pilot hole it will work OK. But....... as underthetire says, a counter bore would be the best tool to use. They are piloted and are designed for making counterbores.
    Jim Dawson
    Sandy, Oregon, USA
  1. Helix bore with a plunge mill?
    By jbranting in forum MetalWork Discussion
    Last Post: 11-21-2017, 10:30 PM
  2. 304 stainless steel bore chip issue
    By makipsee in forum CNC Swiss Screw Machines
    Last Post: 02-19-2015, 12:28 AM
  3. Bore Bar...Carbide vs. Steel
    By weihmue in forum MetalWork Discussion
    Last Post: 06-20-2012, 08:49 PM
  4. Circle interpolation (counter bore)
    By MBG in forum Mastercam
    Last Post: 02-08-2009, 12:22 AM
  5. Counter Bore Steps
    By Big John T in forum BobCad-Cam
    Last Post: 02-28-2007, 09:54 PM
