586,069 active members*
3,554 visitors online*
    Oct 2015
    14
    Unhappy Laser Tube going bad or Power questions
    Hello, I have an extra tube that came with my machine that was never used. I recently started using it and it's only been a month. Last night it suddenly lost most of its power mid-cut. After checking focus I went home then came back in this morning. I was excited to find the laser cutting at full power again but it only lasted about 30 minutes before it lost almost all power and was barely cutting. I checked the lens for damage then checked the focus. I noticed that the laser was firing a circle with an empty middle. I then started to trouble shoot starting at the tube itself. I fired the tube onto a piece of wood and got the same thing, low power and a circle with an empty middle. I tested the power supply next and used the resister that came with the laser. The power was firing at full power so I've determined that the supply was fine. I also learned that there's a lens in the tube itself and I did a visual check looking in the end of the tube and all looked fine. I also did a visual check of the tube which looks fine. That's about as far as I've gotten but at this point I fear it's the tube that's gone or if not I don't know what else to troubleshoot. Any ideas? I've attached a photo of what the laser looks like when it hits the piece. 150W Chinese tube water chilled
    Nov 2008
    643
    Re: Laser Tube going bad or Power questions
    I had the same thing and the tube was gone. What temperature was the water? How many milliamps were you drawing?
    Oct 2015
    14
    The water temp is fine. Same as it's always been. The only thing that puzzles me is that the laser light is purple and everything I read says that a purple light means the tube is good. Also, why would it work after sitting for then night for 30 more minutes? Either it has gas or it doesn't right? I didn't see any slow decline in the power, it just instantly lost power.
    Oct 2015
    14
    I'm only drawing 6ma since the problem arose. Using the resistor test (bypassing the tube) it's almost 40MA,. There is a slight arch at the end before it passes through the end but if what an arching problem why would it lose power? I would think the power would be the same.
  1. Replies: 0
    Last Post: 04-04-2018, 06:49 PM
  2. Replies: 0
    Last Post: 04-04-2018, 06:42 PM
  3. Replies: 0
    Last Post: 04-12-2017, 08:51 PM
  4. Laser power meter for testing laser tube power
    By lasertube in forum Commercial Laser
    Last Post: 05-03-2016, 07:10 PM
  5. poor power on 100w reci tube. tube is new. 1290 laser.
    By nate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-05-2015, 07:31 PM
