586,103 active members*
3,531 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Plunging into 1045 100% tool
Results 1 to 6 of 6
    Apr 2018
    Hi all
    We have a large run of counterbores to do in 1045 and 4140. Problem is they are BLIND counter bores. 1" dia, 2" deep plus Running a old mazak with a double table pallet / bed tipped. 001 per inch in x / cat40 holders
    What's my best option for speeds & feeds
    Thanks in advance all,
    May 2017
    56
    Re: Plunging into 1045 100% tool
    With Blind Counterbores I have had the best luck coming in with an Indexable Drill that would give you near a flat bottom and then cleaning up with a Necked End Mill to give you the flat bottom counterbore you need. Here are the 2 tools I'd recommend:
    Tool 1: Kyocera 1" Diameter 2XD Coolant Thru Indexable Magic Drill
    Run at 500 SFM and .0045" IPR. (8.6 IPM)
    This is available in a Kit that includes the Drill Body and (10) Insert with 4 Cutting Edges per Insert. This Drill uses the same insert for the inboard and outboard pockets and gives you near a flat bottom (you will want to leave about .030"-.050" at the bottom of the hole for the End Mill to Clean up), here is an image of the drill profile at the bottom of the hole:
    Tool 2: 3/8" Diameter x 1/2" LOF x 2-1/8" Neck Length x 4 Flute APLUS Coated Variable Pitch End Mill
    This Tool is necked back to give you the clearance you need to come in and clean up bottom of the bore and give you a flat bottom
    Run at 300 SFM and .0018" CLPT (3,056 RPM and 22 IPM)
    Hopefully this helps!
    Mike
    www.toolhit.com
    Apr 2018
    Thank you so much...I have passed the info off and was kicked in the N@TS. this ""ISO"" and programmers not knowing much is killing me. Unfortunately I cant use 2 tools. I know sounds dumb right. "Standard" has been set can only use 1 tool.
    You can calculate the speed with this simple formula:
    RPM=SFPM*3.82/CUTTER DIAM.
    Since 1045 and 1040 are medium Carbon steel their SFPM value is the range of 200-250
    For the feeds, I'd suggest 0.10 inches per revolution. That'd work well with 1045 & 1040.
    Try using these values and give me a feedback.
    Thanks.
    Mar 2017
    314
    Quote Originally Posted by ArtHeatSign View Post
    Thanks.
    .1 per rev huh? Sound a little grunty,
    Id like to see that operation, but only if you have some of those Mythbusters blast shields.
    I found info from the file below.
    https://www.heatsign.com/wp-content/...-and-feeds.pdf
  1. K2 CNC 1045 V.2
    By chishgre in forum K2CNC
    Last Post: 12-23-2017, 02:38 AM
  2. MILLING GROOVE IN 1045 STEEL WITH TINY TOOL
    By NIRAV1OO7 in forum G-Code Programing
    Last Post: 04-12-2014, 01:48 AM
  3. MILLING GROOVE IN 1045 STEEL WITH TINY TOOL
    Last Post: 04-11-2014, 01:13 PM
  4. Tool plunging at beginning of operation + lost files.
    By JackWilliam in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-17-2013, 03:29 PM
  5. Tool Plunging on Prototrak
    By dkrenfrow in forum Mastercam
    Last Post: 02-01-2012, 08:46 PM
