586,356 active members*
2,776 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Proper way to clean chips from machine
Results 1 to 3 of 3
    Jan 2010
    78
    I recently purchased my Partner 1. Along with an array of other probelms, there are alot of chips in the machine i would like to clean up. Especially inside the Y axis area.
    Could I spray down the entire machine with a hose and maybe a cleaning solution like Simple Green or Purple Power?
    Or are there areas I want to avoid getting wet?
    Dec 2013
    5717
    Re: Proper way to clean chips from machine
    I don't think you want to use a water base cleaner on your machine unless you are going to take it completely apart for a cleaning. A petroleum based solvent would be better. Another option is to use non-flammable brake parts cleaner, but use in a well ventilated area.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2010
    529
    I used Mineral Spirits on the upper portions of the machine and washed everything down into the sump (Partner 4 which is a knee mill). Then I mixed ZEP Purple industrial cleaner with water and using an old shop vac (that I threw away after this), sucked the tramp oil and mineral spirits out, and then flushed multiple times with the Zep, and sucked it dry. Worked very well and now I only use MQL lubricant and if my sump fills up, to will all be way oils dripping down ingot he machine base.
  1. How to clean dried coolant, oil, and chips?
    By Jim27 in forum Uncategorised MetalWorking Machines
    Last Post: 03-02-2018, 12:20 AM
  2. How Clean do you keep your machine?
    By ozzie34231 in forum Polls
    Last Post: 08-27-2015, 09:38 AM
  3. Tormach Users, How do you clean up your chips.
    By Stevos758 in forum Tormach Personal CNC Mill
    Last Post: 05-02-2015, 04:41 PM
  4. Scrap value quesiton, chips vs chunks. Coolant mixed with chips?
    By trialanderror in forum Uncategorised MetalWorking Machines
    Last Post: 10-04-2013, 12:08 AM
  5. My First CNC Machine, Mr. Chips
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 02-10-2007, 04:04 PM
