586,058 active members*
3,712 visitors online*
Thread: UC300ETH BOB
Results 1 to 7 of 7
    Apr 2018
    6
    UC300ETH BOB
    What is up my dudes.
    I'm building a milling machine were I would like to try out the UC300ETH. However I'm confused to which BOB I should use. The official -5LPT got a few ICs on it, but i don't know what it really does or what it is good for. The UB1 is crammed, but it doesn't seem to do much more than light some leds, convert some dc voltages and optically isolate. Which board should i use and why?
    Re: UC300ETH BOB
    The 5Lpt is not a breakout board. It's a motherboard, that you plug your breakout board into.
    The UB1 has lot of features.
    0-10v speed control
    Relays
    Differential step/direct
    Analog I/O
    Charge pump.
    24V I/O
    Apr 2013
    1899
    Re: UC300ETH BOB
    Quote Originally Posted by Nissen View Post
    The UC300ETH is a motion controller. I think you should visit CNC Drive and download the manual. It explains how to connect to a BOB.
    Apr 2018
    6
    Re: UC300ETH BOB
    So the 5LPT alone isn't enough to make it a complete controller? In that case i would suppose the UB1 to be the only proper BOB...
    Re: UC300ETH BOB
    If you plan on buying a UB-1, don't buy a 5LPT, as it's not required with the UB-1.
    Apr 2018
    6
    Re: UC300ETH BOB
    Ok, can the UC300eth and UB-1 combo be used for simulations 5 axis in UCCNC?
    Apr 2013
    1899
    Re: UC300ETH BOB
    What do you mean by "simulations"? The UC300ETH is a 5 axis motion controller, it can move/control 5 axes simultaneously.
  1. UC300ETH, M45, C25 - problem with inputs
    By motogeeking in forum UCCNC Control Software
    Last Post: 07-03-2022, 10:14 PM
  2. New UC300ETH breakout board.
    By ger21 in forum UCCNC Control Software
    Last Post: 09-22-2021, 09:36 PM
  3. UC100 vs UC300ETH-5LPT
    By Bad Wolf in forum UCCNC Control Software
    Last Post: 02-15-2020, 03:18 PM
  4. UC300ETH not connecting
    By Andrew22 in forum UCCNC Control Software
    Last Post: 03-20-2018, 11:40 PM
  5. UC300ETH-5LPT Supplier
    By Tim_DGE in forum South Africa Club House
    Last Post: 02-23-2018, 05:05 PM
