586,051 active members*
3,666 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Madcam Ballnose depth
    Apr 2018
    Hi Guys, I am new to madcam so please be patient with me. I am having an issue with the depth of the ballnose. I have set madcam to calculate from the tip of the ballnose but had it cut into the table the depth of the radius. Also when I do pocketing after the roughing it seems to be an odd 4.8mm above the job? Any help would be greatly appreciated. I am using a 3 axis cnc Router
    Cheers
    Rollan
    Mar 2018
    10
    Re: Madcam Ballnose depth
    What kind of machine / controller are you using? Any chance the machine is trying to do some sort of radius compensation that MadCam is already handling?
  1. Bad tapered ballnose finnishing
    By davidescu76 in forum WoodWorking Topics
    Last Post: 02-09-2016, 12:51 AM
  2. Replies: 2
    Last Post: 02-04-2012, 05:27 PM
  3. need to buy 1 - 3mm ballnose
    By 15mgtar in forum Want To Buy...Need help!
    Last Post: 02-24-2010, 04:59 PM
  4. ballnose bits
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 01-31-2010, 04:40 AM
  5. What can a ballnose offer in 2D?
    By HankMcSpank in forum CNC Tooling
    Last Post: 07-07-2009, 12:26 AM
