586,071 active members*
4,360 visitors online*
    Oct 2011
    205
    monitor help...
    Hey guys, looking like I came across a dead monitor in an Arrow2. It doesn't have the normal vga style connection. Is there some sort of adapter I can use to hook up a normal monitor?
    Mar 2011
    463
    What WS board do you have? Some of them have a VGA port on the board and use a video card for the signal to the operator station (they were all pre series 2 machines though unless someone has swapped it out). If you do have one of these, you can get a VGA display directly from the WS board, but depending n where the issue is, may lose the rest of the op station functionality.
    The connector you mentioned does not use a standard VGA signal, and unlike VGA, that connector also provides power and data for the op station.
    What is it doing (or not doing) that you decided it is the display? I have seen the backlight fail on some of these LCD monitors but the rest of the op station is still functioning. I have also seen the WS board (or video card) cause the display to not work as well.
    Oct 2011
    205
    Re: monitor help...
    Could possibly be the back-light that has failed, but Ive got it sorted out for now.
  1. Replace old CRT monitor to LCD monitor
    By =aike= in forum Okuma
    Last Post: 01-16-2020, 08:29 AM
  2. U10M spindle load monitor and monitor mode
    By myhäje in forum Okuma
    Last Post: 02-21-2017, 08:45 AM
  3. HL-2 monitor very dim
    By 11toma in forum Haas Lathes
    Last Post: 08-15-2009, 04:17 AM
  4. monitor
    By CASTLEVILLE in forum Bridgeport / Hardinge Mills
    Last Post: 10-11-2007, 12:37 AM
