586,060 active members*
3,380 visitors online*
Results 1 to 7 of 7
    Apr 2018
    5
    Floppy failure 80 m15-5
    M15-5
    serial 4189
    pcm 6890 bios rev 1.7 updated 1/7/2003 400mhz 66x6
    on boot up i get a floppy 80 error. I tried replacing floppy drive with another and still get the error i also replaced the ribbon cable and also still get the error.
    I noticed that my motherboard has a slot cn3 for USB Drives.. I checked the cmos and it is keeping time etc so battery should be good
    What can we do to troubleshoot the floppy further and or ad USB
    Feb 2008
    280
    Re: Floppy failure 80 m15-5
    Is the floppy drive type correctly entered in the Standard CMOS Setup menu? If something other than 3.5" 1.44MB is selected, you would probably get errors.
    Otherwise, it is sounding like a problem with the FDD controller on the motherboard.
    Are you running DOS and CNC7, or Linux and CNC10?
    If you are running Linux and CNC10, and have CNC10 v1.21 or higher, then you just need a cable pigtail in order to use USB thumb drives.
    Apr 2018
    5
    I have dos cnc7
    Cmos is setup correctly
    Mar 2016
    42
    Unfortunately, USB is not supported in DOS. Does the LED on the floppy drive ever turn on when you power the system up? It could be that the floppy ribbon cable isn't installed correctly. Make sure that the red line, which designates pin 1, is facing towards the center of the floppy drive. Another thing to check is to make sure that you are getting power to the floppy drive. Are you sure that the replacement floppy drive was in fact good? The only other option that I can think of would be a USB-to-floppy emulator which allows you to use USB on a DOS based system. The only catch is that the USB has to be partitioned into 1.44MB partitions. If the issue is in fact with the motherboard, though, the emulator will still not work.
    Apr 2018
    5
    What is the cost of installing Windows in the windows base system on this motherboard
    Mar 2016
    42
    I'm not exactly sure what you are asking. If you are asking about converting your existing M15 console into the new Centroid CNC11 system which runs on Windows 10 CENTROID M15 CNC control upgrade to M39S, Trade in your M15 for a new M39S., you are looking at approximately $5500. If you are asking about installing a new hard with Windows installed, you can do that but you will also need to install the CNC7 software onto the hard drive, and the CNC7 software is a DOS based software. Since CNC7 is a DOS based software, the Windows that you install can't be any higher than Windows 98 as Microsoft stopped using true DOS after that version. There is software out there such as DOSBox that allows you to run DOS based programs in a new Windows environment but I can't guarantee that will work as something like that has never been tested. If you wanted to just get USB support onto that control, an easier way would be to get a new SSHD with CNC10 v2.36 and install a USB pigtail onto that motherboard like cncsnw mentioned.
    Apr 2013
    28
    GMJERIC, were you able to get this resolved? I had a very similar issue a couple days ago but was getting error 40 instead of 80. I think they may point to the same error though. I assume your floppy drive worked before? The way I got around it was making the B: drive the 1.44 MB 3.5" Floppy, not the A drive, then set Swap Floppy Drive (or something like that) in the BIOS to Enabled. Sounds hokey but works. The PC still sees the floppy as A: even though there is no A: drive enabled.
  1. floppy to usb
    By terry reber in forum Okuma
    Last Post: 08-29-2017, 03:08 PM
  2. EMUFDD 5.0 Floppy-to-Network & Floppy-to-USB upgrading
    By blackvision in forum News Announcements
    Last Post: 01-19-2013, 09:44 PM
  3. Floppy Controller card PCI floppy drive USB kit
    By logamuthu in forum Want To Buy...Need help!
    Last Post: 11-07-2011, 05:23 PM
  4. Floppy
    By Ron22 in forum Haas Mills
    Last Post: 02-02-2011, 07:29 PM
  5. 3.5 floppy
    By Delvis in forum Fadal
    Last Post: 03-27-2010, 06:02 AM
