586,052 active members*
4,339 visitors online*
Results 1 to 11 of 11
    Sep 2003
    1469
    Import a solidworks file into VcarvePro
    Is there a way to import a file from solidworks to VcarvePro and have all the diminsions be the same as in solidworks?
    HH
    Sep 2009
    1856
    Re: Import a solidworks file into VcarvePro
    yes the model should be the same as long as it is a format Vcarve can use.
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Try exporting an .stl from Solidworks.
    Sep 2003
    1469
    Quote Originally Posted by daniellyall View Post
    I tried exporting both DFX and DRG extensions and neither one would be the same dimensions as the original SW file.
    - - - Updated - - -
    Thanks Ger. Ill try that.
    HH
    If you are modeling in inches, the exports are probably in mm's.
    Sep 2003
    1469
    No both inches.
    How much are the dimensions off?
    Sep 2003
    1469
    I tried to bring in a STL file but .STL wasn’t an option to open in VCP?
    I’ll see if I still have the other files and how many inches it was.
    Thanks Ger
    HH
    What version of V Carve Pro?
    File > Import > Import Component/3D model
    Sep 2003
    1469
    I attached the file from a Dwg format, originally it is about 60" in the X axis but when I bring it in it is roughly 5.5".
    don't understand why it is reducing the size, original file was in SolidWorks.
    thanks Ger
    HH
    Because you are exporting a drawing page. It says right on it that it's scaled 20:1.
    You need to create the views in your drawing at 1:1 scale.
  1. I can't import model from Solidworks
    By bob69 in forum FeatureCAM CAD/CAM
    Last Post: 09-07-2016, 10:30 AM
  2. Replies: 16
    Last Post: 10-12-2011, 11:35 AM
  3. Mastercam & Solidworks 2010 file import
    By foxsquirrel in forum Mastercam
    Last Post: 04-04-2010, 09:07 PM
  4. Import form Solidworks
    By Stupidav in forum Surfcam
    Last Post: 12-04-2009, 05:12 PM
  5. import solidworks
    By daisydog in forum Rhinocam
    Last Post: 08-25-2009, 01:07 PM
