586,052 active members*
3,935 visitors online*
Thread: Fixturing
    Feb 2017
    12
    Fixturing
    I’m just curious as to what others are doing to locate and square their materials and fixtures squarely in the machine? Can one make a “tooling” plate from their spoil board and have pieces turned that fit snugly in the holes to square things up? What about bronze or brass bushings with holes for located pins that a fixture can index on? As always, pictures are a great help as well. My thought is a grid of holes coupled with a couple t slots for hold downs and then a couple of the bushings with the locator holes and then adding additional ones as the need arises. With the bushings you could then just home the machine and reduce setup times when repeating parts runs.
    Apr 2004
    326
    Re: Fixturing
    That's pretty much what I do. I have a grid of 20mm- holes bored by the CNC along with T-slots in the spoil board. I use parf dogs in the holes to set the jigs against.
    You can see this in many of my videos: https://www.youtube.com/channel/UCH-...TYdNS4EkQGsVUQ
    The other I did was to have the spoil board outline cut by the CNC after it was bolted down (and during creation of the holes and t-slots). So the edges of the spoil board are also square to the machine and I can just locate the jigs along the edge of a large square against the side.
  1. Implementing Fixturing
    By arikaa in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 06-23-2014, 08:14 AM
  2. Fixturing question
    By tbaker2500 in forum Tormach Personal CNC Mill
    Last Post: 10-24-2012, 09:14 AM
  3. Fixturing Advice
    By muddawg in forum Open Source CNC Machine Designs
    Last Post: 04-27-2012, 09:35 AM
  4. New to 4 axis fixturing
    By m-134b in forum Work Fixtures / Hold-Down Solutions
    Last Post: 02-01-2010, 06:19 PM
