586,075 active members*
4,143 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Servo amplifier/drive input wiring assistance please
    Jan 2018
    1516
    I'll try to keep it short.
    Looking at upgrading the spindle to a 1.5kw servo motor to control in mach3.
    Just need to know which inputs/outputs to use on the CN2 connection for: on/off, speed control, and if poss e-stop for if the spindle gets stuck so it stops Mach.
    The board I have is this one:
    Manual:
    https://warp9td.com/images/BOB_Vendo...line/ST-V2.pdf
    I've found wiring for a different VFD drive:
    Video:
    https://www.youtube.com/watch?v=xpb9JUaWl7M
    Shows that on the board:
    The 2 connections for spindle on/off control goes top conn to FOR and bottom conn goes to DCM
    The 2 for the 0-10V spindle speed output goes top to VI and bottom to ACM
    Unsure if there is a stop circuit there.
    The servo I'm looking at is something like this:
    https://www.aliexpress.com/item/130S...355475440.html
    But the wiring for the CN2 inputs/outputs I have no idea on and have been searching a while so I thought you guys may be of assistance. The rest is fairly straightforward.
    Wiring diagram is like this:
    Thanks in advance.
    Daz.
    Jan 2018
    1516
    Re: Servo amplifier/drive input wiring assistance please
    O.k. guys/gals.
    A little update. I think I've found the manual for the driver type which is this one:
    https://www.fasttobuy.com//download/...anual_V3.0.pdf
    The wiring diagram for speed/torque mode is on page 20.
    Looks like the the speed/voltage regulation is + VREF & - AGND.
    Looking at the diagram and vid with the VI and ACM inputs previously I assume the line that went to ACM input from the BOB is the negative? Correct?
    Just need to know which to use for on/off and e-stop
    Thanks.
    Daz.
  1. Replies: 3
    Last Post: 02-06-2020, 08:33 PM
  2. Sanyo Denki 60BA SERVO AMPLIFIER capacitor wiring.
    By ngocdong2001 in forum Servo Motors / Drives
    Last Post: 10-11-2014, 10:28 AM
  3. Servo drive / Servo Amplifier
    By Ken_Shea in forum Servo Motors / Drives
    Last Post: 07-10-2007, 11:12 PM
  4. How to drive Analog Servo Input +/- 10V
    By gurvy in forum CNC Machine Related Electronics
    Last Post: 05-31-2007, 05:31 AM
