Hi friends
The stepper motors at mini cnc are running noisy.And the rpm does not exceed 250 mm / min.
Can you provide help for the solution.
System:
Hi friends
System:
Stepper motors are noisy, not much can be done about it. The only thing I found that helps a little bit is changing the coupler between the motor and the screw.
Plum couplings:
Attachment 424446
seem to transfer less noise than spiral cut couplings:
Attachment 424448
Motor neden devir artm?yor acaba?
Do a Search for setting up and tuning a Stepper motor.
Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
@wmgeorge yard?m için buray? seçtim umar?m.Burda o ki?i vard?r.
