586,060 active members*
4,282 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > through spindle coolant leaking from back of head stock!!
    Aug 2010
    188
    hey everyone, ive got an okuma MA650 with a bit of an issue, when i turn the thru spindle coolant on i have low pressure at the tool and a bunch of coolant coming out of the back of the headstock inclosure. it looks to be coming from three plastic braided lines that come from the top of the spindle shaft and are routed down to the bottom of the headstock enclosure. what is my solution?
    Jun 2015
    4154
    Re: through spindle coolant leaking from back of head stock!!
    is there an o-ring on the pull stud ?
    Aug 2010
    188
    yes there is, but this problem happens no matter of spindle condition, tool in, tool out, clamped, unclamped, same thing happens. coolant pours out the back.
    Mar 2018
    12
    Quote Originally Posted by jay_dizzle View Post
    Hi.
    Maybe a not return valve on the coolant circuit are not working fine.
    Inviato dal mio GT-I9301I utilizzando Tapatalk
    Apr 2009
    1262
    You've probably got a bad rotary union at the top of the spindle.
    Experience is what you get just after you needed it.
  1. Replies: 8
    Last Post: 08-09-2016, 04:55 AM
  2. Spindle assembly leaking coolant.
    By l u k e in forum Haas Mills
    Last Post: 03-19-2011, 07:53 PM
  3. Craftex 10x18 lathe leaking from head stock
    By chronic in forum Mini Lathe
    Last Post: 11-24-2010, 06:04 AM
  4. thru spindle coolant leaking
    By GARY DAVIS in forum Fadal
    Last Post: 03-25-2008, 01:28 PM
  5. Coolant leaking slowly on back of VF3
    By Rocko1 in forum Haas Mills
    Last Post: 12-07-2007, 12:38 AM
