586,075 active members*
3,614 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > INDRAMAT KDA 3.2-150-3-A00-W1
Results 1 to 2 of 2
    Jul 2016
    108
    Hi there
    What I want to ask is about Spindle Drive, which is:
    KDA 3.2 series.
    when I connect the " Control Voltage Bus ( X1 pin assignment 16way bus ), unfortunately, the power unit stop output voltage( eliminate POK ) and nothing mirrors in the spindle drive.
    also, I remove the 24-volt wire from Power control board( Inside of the spindle drive unit, Which I attached the picture in post) POK goes OK green and spindle drives Fault ( red LED) turns ON.
    Does anybody have the same experience?
    any help will be appreciated kindly.
    With Regards
    Russell
    Jul 2016
    108
    Re: INDRAMAT KDA 3.2-150-3-A00-W1
    here is the 2nd connection, Gray & Green.
  1. Indramat TVD 1.2-15-03 no power
    By scheffers in forum Servo Motors / Drives
    Last Post: 03-06-2022, 02:26 PM
  2. M-parametrs Indramat 2AD
    By Smouk in forum Controller & Computer Solutions
    Last Post: 04-04-2018, 02:10 PM
  3. indramat parts
    By mikemcg in forum Uncategorised MetalWorking Machines
    Last Post: 07-12-2012, 08:08 PM
  4. Indramat
    By xclr82xtc in forum Servo Motors / Drives
    Last Post: 10-10-2010, 08:00 AM
