586,060 active members*
4,553 visitors online*
    May 2010
    Mazatrol M-32 System
    Hi there
    I'd like to know if I should leave the Floppy Disk BND-212W001-B1 in the Mill all the time?? It usually stays in there but I've recently had to replace the battery and not sure if the floppy will get damaged/compromised if left in the mill continuously..Thanx in advance
    Mar 2009
    109
    Re: Mazatrol M-32 System
    If the system disk loads every time you power on, then you need to leave the disk in. If you want to have the disk out, then you need to make sure the large motorcycle battery is good.
  1. Mazatrol Cam T2 (Hardware & System manual)
    By CNC SERVICE in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-11-2022, 09:34 AM
  2. Mazatrol M32 system variables
    By felipe666 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-19-2017, 09:17 PM
  3. Card in the CNC system Mazatrol 640 Vertical Milling Machine
    By Viktoriia in forum CNC Machine Related Electronics
    Last Post: 05-19-2017, 06:30 PM
  4. need help with system variables list for mazatrol m/t pro control
    By uperez in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-25-2007, 04:21 PM
