586,082 active members*
3,530 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Max Speed settings?
    Jan 2004
    236
    Max Speed settings?
    Hey Guys,
    I hooked up my xylotex board this evening and spun the motors. Relax, don't worry... my machine is already built! (i.e. I didn't put the cart in front of the horse!)
    I am using turbocnc to drive some 116oz Powermax II motors. I also have a 24v power supply and the motors are wired in parallel. I really thought the motors were a little stronger than that.
    Does anyone have anything similar? I'm trying to find out what kinds of speeds you guys are using for
    start speed:
    max speed :
    acceleration:
    Any suggestions welcomed!
    Mike...
    430
    I have a similar setup but I use Mach2. With 1/4-20 screws I get 46 in/min and I have the acceleration set almost at the steepest setting and speed at absolute max. I have no problems with missing steps at all.
    co
  1. CNC Controlled Spindle motor speed control
    By gregmary in forum CNC Machine Related Electronics
    Last Post: 02-28-2009, 02:01 AM
  2. mach2 i can jog at a max speed of 30 ipm but it wont feed that high?
    By mike10 in forum Mach Software (ArtSoft software)
    Last Post: 03-21-2005, 12:28 PM
  3. Speed how fast an axis can move?
    By jlagran he in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-05-2005, 05:05 AM
  4. Max. Pulse Current-peak or continuous?
    By Splint in forum CNC Machine Related Electronics
    Last Post: 03-27-2004, 07:26 AM
  5. min speed exceeds max speed for axis "x"?
    By ljoe1969 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-19-2004, 02:49 PM
