586,072 active members*
4,681 visitors online*
IndustryArena Forum > CAM Software > CamBam > The CamBam forum is out of order
Results 1 to 10 of 10
    Dec 2013
    11
    Lightbulb The CamBam forum is out of order
    Hello,
    Due to a hard disk failure, the CamBam.co.uk forum is out of order since the afternoon 20 April 2018. (French time)
    Be patient, the repair is in progress.
    David
    Dec 2013
    11
    Re: The CamBam forum is out of order
    Hello
    Because the install files are also on the same server, during the forum repairing you can download the 0.98P and 1.014 versions on this page (for Windows only)
    http://www.atelier-des-fougeres.fr/C...ugin_menu.html
    David
    Oct 2008
    2100
    I was just coming over here to make that announcement. I see you beat me to it.
    Bob La Londe
    http://www.YumaBassMan.com
    Dec 2013
    11
    Re
    Andy have setup a read only version of the forum (January backup), maybe it can be useful for reference (attachment not available) until all is repaired ..
    CamBam - Index
    David
    Hello - new user here. Make guitars for a living. Any input or suggestions are appreciated. One thing I noticed right away is the post processor drop down menu does not list generic grbl which is what I need as I have an Arduino controller.
    Vegas Guitars Custom Shop
    http://vegasguitars.com
    Oct 2008
    2100
    With the forum down I am not sure where to direct you, but there are users using grbl. Not me though. Sorry.
    Bob La Londe
    Dec 2013
    11
    Quote Originally Posted by VGcustomshop View Post
    Hello
    I attach a basic GRBL post pro to this message.
    You can also use this plugin to drive a GRBL machine directly from Cambam (I think, but not sure, that GRBL 1.1 is needed for this plugin)
    http://www.atelier-des-fougeres.fr/C...BLmachine.html
    David
    Attached Files Attached Files
    Quote Originally Posted by dh42 View Post
    Hello
    David
    Many thanks David - much appreciated. Both of my CNC machines are grbl 1.1 - Unfortunately after putting the file in the CamBam "plugins" folder grbl still does not show up in the drop down menu. How do I install this file correctly? Thanks, N
    Dec 2013
    11
    Nice ; I can't use it, but if I well understand how the plugin works, no GRBL PP is needed with it ; ... and the plugin allow to manage toolchange and Z zeroing during a machining process.
    David
    Oct 2008
    2100
    If you got to the plugins directory with your system file manager and right click the plug-in file to bring up the properties there may be a check box to unblock the plugin. That is an operating system thing. Not a CamBam thing. I started noticing it under Windows 10 every time I add a plugin.
    Bob La Londe
  1. Is CamBam forum down?
    By lancut in forum CamBam
    Last Post: 10-05-2014, 01:25 PM
  2. CamBam UK forum
    By w7bcw in forum CamBam
    Last Post: 08-14-2014, 08:48 AM
  3. Anyone alive at CAMBAM forum
    By ozzie34231 in forum CamBam
    Last Post: 11-04-2012, 04:49 PM
