586,121 active members*
3,630 visitors online*
Results 1 to 7 of 7
    Feb 2008
    216
    How to add two buttons to C code Magbox!
    I want to have two click buttons in a message box prompt in my too change C Code, one to proceed with the change and one to abort the start of the tool change operation. Anyone know how to do that?
    Thanks, Dan
    May 2006
    4045
    Re: How to add two buttons to C code Magbox!
    Hi Dan,
    You might see the MessageBox.c example:
    Code:
    #include "KMotionDef.h"
    #define TMP 10 // which spare persist to use to transfer data
    #include "KflopToKMotionCNCFunctions.c"
    main()
        int Answer;
        Answer = MsgBox("Hello World",MB_YESNO|MB_ICONEXCLAMATION);
        if (Answer == IDYES)
            printf("Answer is Yes\n");
        else
            printf("Answer is No\n");
    It includes a Yes and No button. Using MB_OKCANCEL that includes OK and Cancel might be more appropriate. See KMotionDef.h for other options.
    Regards
    TK
    http://dynomotion.com
    Feb 2008
    216
    Quote Originally Posted by TomKerekes View Post
    Hi Dan,
    Code:
    main()
        int Answer;
        else
    Regards
    Thanks Tom,
    I can't seem to get it to work. I want it to continue with the code if "OK" (return 1) is clicked and exit the tool change sequence if "cancel" is clicked (return 0). But i keep getting a C code error when i try to compile. I seem to be a lot better with examples of code then without lol
    May 2006
    4045
    Hi Dan,
    I don't quite understand what you mean. Do you want to make a function that returns 1 or 0 depending on the answer? Post your code and the error and we can check it.
    Regards
    TK
    Feb 2008
    216
    Here it is, I've modified the Automatic Tool change to allow for manual installation of 5 tools Tool 101-105 and the selection of Laser as tool 77, Drill is tool 99 and Laser cross hairs as tool 88. It's gotten alot more complicated since the initial version
    It's a work in progress so the formatting sucks. But basically it all works currently. The current code has a message box prompt that says your about to initiate a manual tool change and you click ok and it continues with the tool change. I would like to make is a OK/Cancel option box to abort the tool change entirely if it was incorrectly selected for some reason. It's near the start of the code i made square marker of a bunch of ////// to show where. Once i get this cleaned up i'll share with the dynomotion forum and make a better video.
    Dan
    May 2006
    4045
    Hi Dan,
    Try changing:
    MsgBox(s, MB_ICONHAND | MB_OK);
    To
    if (MsgBox(s, MB_ICONHAND | MB_OKCANCEL)==IDCANCEL) return 1;
    Regards
    TK
    Feb 2008
    216
    Thanks Tom, We ran out of time Sunday to test this out. Next time I'm back in town we will test it and let you know how it went.
    -Dan
  1. The SeCret Buttons...........
    By Bob316 in forum Commercial CNC Wood Routers
    Last Post: 08-01-2016, 10:59 PM
  2. Those Big Red Stopper Buttons?
    By crash5050 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2010, 09:25 PM
  3. buttons going out? need help
    By DerHammer in forum Fanuc
    Last Post: 03-10-2008, 04:25 AM
