586,069 active members*
3,563 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Missing codes in auto tool changer
    Jan 2017
    84
    Hi there
    I was going over the auto Tool changer codes “M6Start”, and It appears to me that some codes are missing there, as the codes executing, and after Calling the MovePos() subroutine, it moves to the position of the Old Tool coordinates and then it goes down to ("G53 Z" & ToolDown ) So far so good, but then before releasing the old tool, Shouldn’t it to move forward or backward let’s say a value of 50 mm in order to basically force in or slide in the collet chuck to the Collet chuck Holder (that plastic u shape chuck holder in an array of let’s say 8 tool Holder) then releasing the old tool?
    And similar action on new tool pick up procedure?
    Regards
    Jhonansaro
    Re: Missing codes in auto tool changer
    Where did you get the M6Start macro from? Unless it came from the manufacturer of the machine, you'll likely need to write your own that works with your machine.
    Jan 2017
    84
    Hi Gerry
    you provided the link of it your self, it is from the mach support.
    on this issue, do I need to use the M6End code, Please explain, and If I do, then how should i call it? is it in the "ToolChange Pos." bottom? right after the M6start?
    also on modifying the codes in order to suite my needs, what about the following code edition;
    Call MovePos(OldTool)
    While IsMoving()
    Wend
    Code "G53 Z" & ToolDown
    Code "G4 P.75"
    While IsMoving()
    Wend
    Code "G53 X" & XPos & " Y" & YPos+50
    While IsMoving()
    Wend
    Is it going to work? basically what I want to do is to slide the chuck into the Chuck holder by moving it 50 mm
    regards
    jhonansaro
  1. Auto tool changer Drum type tool magazine.
    By maylin1105 in forum News Announcements
    Last Post: 02-18-2012, 09:44 AM
  2. Auto tool changer Armless type tool magazine.
    Last Post: 02-16-2012, 03:27 AM
  3. Auto tool changer-Umbrella type tool magazine.
    Last Post: 02-15-2012, 03:38 AM
  4. Auto tool changer ?
    By Rich05 in forum Charter Oak Automation Support Forum
    Last Post: 10-18-2011, 08:31 PM
  5. Auto tool changer
    By jkarisny in forum DIY CNC Router Table Machines
    Last Post: 09-30-2011, 12:08 PM
