586,269 active members*
3,204 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Pain in finding zero position, Fadal 6030
Results 1 to 9 of 9
    Apr 2013
    8
    Hello Fadal experts,
    I am forwarding this question about Fadal 6030, yr.-99
    This machine works generally quite well except the cold start
    procedure. Its owner described the symptons like this:
    When in CS procedure, Z, and Y reference points are
    found immediately and always correctly.
    X-axis zero tracking seeks for some time and ends up to
    error display something like "home position not found" (I don't
    remember exact expression) Then, after persistent trials it
    finally succeeds but may take some nerve wrecking hours. As
    you may quess this machine is never intentionally shut down
    (except for display). Mains power-downs happens sometimes,
    usually only fraction of seconds but here we are again....
    (Not to mention what this continuous power-on affects to
    electronics life span, its power-on time is huge allready...?)
    I asked the owner if/how he had tried starting positions
    nearby indicator marks and with what result. He said there is
    some marginal around indicator but it remains unclear if it
    is any good to try beyond indicators close proximity. Thus
    our conclution was that indicator is correctly located.
    Correct...? Anyway, sometimes it ends up to find home position
    which is clearly aside of indicator. The owner said, referring
    to the burden of finding at least any home position, he gladly
    accepts it because after that the machine work again... until
    next mains glitch.
    Unfortunately the history of that problem is unknown.
    Only we know that it has been around by previous owner...
    who "forget" to mention it until commissioning on present
    owner. (He didn't shut it down either, that we know)
    Are there anybody who exactly knows Fadal homing system?
    The owner believes that this problem is somehow related to
    linear scales equipped, some contradictional data between
    encoder and linear scale? I am not convinced that the scales
    have anything to do with this but do not know. I always thought
    that scales belong only to the outermost servo control loop and
    do not contribute to finding/defining machine reference point.
    Is it simply encoder index pulse that defines home position
    so that it could be (mistakenly) found anywhere within slide travel?
    (periodically every ball screw revolution?)
    I found this:
    Fadal Maintenance Manual
    Section 16: Troubleshooting, page 531
    <http://www.fadalcnc.com/media/pdf/tech_docs_1/Maintenance_Manual/Troubleshooting.pdf>
    "Problem Positioning Slides to Zero
    This error only occurs during Cold Start. When the Glass Slides
    are not aligned close enough to the indicators during Cold Start.
    Place the machine in Jog and manually align the Cold Start
    indicators more accurately."
    Does this mean that glass slides has something to do
    with defining zero position? If so, does encoder index
    pulse have any role after all?
    Thanks for your help.
    156
    Quote Originally Posted by Mjerica View Post
    next mains glitch.
    I found this:
    The machine should find the same zero within ,060 of the mark. If the machine is a little off the mark repeatedly. Move the marker to where the machine has gone. From that point on it should repeat.
    Apr 2013
    8
    Re: Pain in finding zero position, Fadal 6030
    Hi, Paul
    The owner of the machine said he would be happy to find
    at least any zero. Mostly, when a zero is finally found, sometimes
    after hours of trying, it is correct.
    The reason for erraneous zero might even be the
    frustration of the exhausting situation. The owner said he
    sometimes had begun to try seeking zero anywhere nearby indicator,
    I have never been around there when this have been taking place.
    Jul 2006
    367
    Hello, I had the same issue on my 3016. It would fault at random times locating the CS position. My Fadal has AC servos and the problem was the encoder. Thus being an AC servo, I couldn't just swap out the encoder. I replaced the the problem servo with a new one. All CS locating problems were solved
    pete
    pete
    Apr 2013
    8
    @slowtwitch: "Thus being an AC servo, I couldn't just swap out the encoder.
    I replaced the the problem servo with a new one."
    - Hi, Pete. That is interesting. That may tell that glas slides, even if equipped,
    have nothing to do with this.
    What was to reason you couldn't swap just the encoder, aren't those
    available separately?
    For an general info.... this machine will probably have planned powerdown
    in next few months because of transfer to another building. I hope i get a
    chance to take a signal sample from encoder at start-up. But before that,
    now at summertime, we might encounter lightning based power-downs.
    Jul 2006
    367
    I guess the biggest issue for not replacing the encoder, was lack of information on how to do it. I'm just a lowly maintenance man who relies on youtube and these forums for info
    pete
    Apr 2013
    8
    @Pete, how did you diagnose the encoder?
    Jul 2006
    367
    I noticed the AC servo hunting for the CS markings. When the CS finally was found (without alarming), it would be at a different location from my marked position. I tried changing the difference in the axis survey settings, but, to no avail. Again, this is an AC servo machine, so the procedure is somewhat different than with a DC servo machine.
    pete
    53
    Fadal machines with scales do take longer to cold start. Yes, the control does use the scale as main feedback, but it also refers to the position of the encoder. If the glass scale is compromised, it will be harder for the machine to zero. Easiest way to diagnose a scale issue is to disconnect the scale before power on, then cold start. If the machine cold starts easily, look at gibs, straps, bearings, then scale. If you are going to check or adjust gibs and straps, you must disconnect the scales also, otherwise you will be fighting the scale while making your adjustments.
    Hope this helps.
  1. Fadal 6030
    By jon_fallon in forum Want To Buy...Need help!
    Last Post: 12-22-2010, 01:37 PM
  2. Post file for FADAL 6030
    By Mopec in forum Esprit
    Last Post: 05-20-2009, 09:03 PM
  3. Anyone interested in a used Fadal 6030
    By JoBwan in forum Want To Buy...Need help!
    Last Post: 03-13-2008, 06:15 PM
  4. Moving Fadal 6030
    By 5th-axis in forum Fadal
    Last Post: 01-04-2008, 06:01 PM
  5. Reman Fadal 6030
    By redman in forum Fadal
    Last Post: 11-23-2007, 08:31 AM
