586,035 active members*
3,712 visitors online*
    Apr 2018
    Interfacing and configuration of ST-V2 board in TurboCNC
    Good time of day.
    I sruggle with configuration of BL-MACH-V11 (see attachments) board and brushless spindle WS55-180 (https://www.banggood.com/400W-12000r...r_warehouse=CN).
    I have selected pin 17 to control EN input of controller and pin 16 to control F/R (direction of rotation).
    The board has regulated 0-10V output to control rotation speed of spindle. The problem is that all information I could get is related to Mach3 software, not TurboCNC. Which pin is in charge of this function and how can I set it up?
    I have googled it and went through manual - no joy.
    Can somebody explain me, how can I set this function in TurboCNC?
    Thanks in advance.
    Re: Interfacing and configuration of ST-V2 board in TurboCNC
    TurboCNC does not have PWM output, so I don't think you can use the 0-10V from that board.
  1. Mechatronics 4axis Bipolar board-instructions/configuration
    By metalworkz in forum Controller Cards
    Last Post: 01-28-2017, 06:33 PM
  2. Replies: 1
    Last Post: 11-20-2016, 04:58 PM
  3. Interfacing
    By knowlzy1824 in forum Mach Software (ArtSoft software)
    Last Post: 10-02-2014, 07:13 AM
  4. Replies: 1
    Last Post: 07-12-2010, 01:45 PM
  5. MACH 2 configuration for Xylotex Board
    By ngr1 in forum Mach Software (ArtSoft software)
    Last Post: 08-13-2004, 07:03 AM
