587,011 active members*
3,752 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Bobart Importing pdf
Results 1 to 6 of 6
    Aug 2006
    133
    I have Bobart and followed the you tube tutorial by Depoalo ([url]https://www.youtube.com/watch?v=4NNZcNNw5RI) for importing vectors from a pdf file.
    The lines came in fine and are clean. The issue is, it appears instead of one line there are 5 lines laid on top of each other. I have started selecting line by line and deleting the top 4 lines so I am left with one. But this is taking a long time for this specific drawing. Is there a faster way to remove these duplicate lines?
    Jun 2008
    1838
    Re: Bobart Importing pdf
    Have you tried using the "Utilities>Reorganise>Erase Doubles" facility ??
    See attached image
    Regards
    Rob
    Dec 2008
    4548
    Couple things to try.
    Closed shape? Try chain selecting a single entity. If you get a good chain, you can hide/layer/color it, the mass delete everything else. Chain selection = shift click
    There is a command = cleanup and optimize/erase doubles. Under utilities.
    This should work if they are actual duplicates. Sometimes though, what "appears" the same, are actually different in vectors.
    In any case, selecting and managing "what to keep" instead of what to delete, in this case will be much faster.
    Aug 2006
    133
    Thanks for the guidance. Did not know about the "erase doubles" command. Seems to have worked on some but less than 20% of the drawing. Focusing on the "what to keep" is a good idea. That will help, but still rough. I wonder why it comes over like that?? Oh well. Thanks
    Dec 2008
    4548
    Quote Originally Posted by becikeja View Post
    Thats going to be a translation of the vector art and all the entities it represents. So it has outlines, the actual splines, fills etc.
    So a "fill" will translate as an edge and not a surface. So the actual outline = entity, fill creates outline = 2, etc etc...
    Apr 2012
    25
    Also remember to use cleanup/optimize when you first vectorize, this helps alot.
  1. BobArt V23 Manual / Guide ? Wanted BobArt Manual
    By BobCAD-Trainee in forum BobCad-Cam
    Last Post: 04-22-2017, 12:28 AM
  2. Need bobart help importing
    By mfabritz in forum BobCad-Cam
    Last Post: 08-26-2015, 03:56 AM
  3. Bobart V25 to V26
    By Gallchobhair in forum BobCad-Cam
    Last Post: 10-19-2014, 10:50 PM
  4. BobArt Pro
    By kdiver58 in forum Want To Buy...Need help!
    Last Post: 06-02-2011, 02:20 PM
  5. BobArt pro x
    By bbergami in forum BobCad-Cam
    Last Post: 06-04-2006, 04:53 AM
