586,042 active members*
3,577 visitors online*
Results 1 to 5 of 5
    Nov 2005
    41
    Y AXIS OVERSHOOT SMALL MOVES
    Have Monarch mill with Fanuc 16-m. While flowline 3d surfacing - most of the motion is in x z axis there are very small moves (+/- .0001 in y axis) within the program. The machine is overshooting these minute y moves leaving dings in the surface finish. looks really bad. The old machine has axis scales. The back lash parameter for y axis is set at 5 whatever that translates to not sure but seems really low for age.
    any one know what's going on?
    Feb 2009
    6028
    Re: Y AXIS OVERSHOOT SMALL MOVES
    Check and report back parameter 1852
    Sent from my SM-T813 using Tapatalk
    Nov 2005
    41
    PAR 1800 RBK is @ 1 so uses both feed and rapid parameter sets
    FEED PAR 1851 @ x5 y5 z0 a2
    RAPID PAR 1852 @ x1 y1 z1 a10
    Mar 2017
    314
    I have tried surfacing on a Monarch "A" type years ago and had similar issues. Fanuc 15a or b. I attributed it to the quill type construction.
    Nov 2005
    41
    Overshoot was happening in area where the ball screw should have the most wear.
    We set 1851 Y parameter to zero and now no more overshoot nor undershoot.
    I am wondering why have backlash parameters at all if machine has scales?
    Why were they set in the first place?
    puzzled...
  1. Jerky Small Straight Line Moves
    By barchdesigns in forum Uncategorised CAM Discussion
    Last Post: 05-26-2016, 12:57 PM
  2. Small g01 moves on big radius?
    By tkgb in forum SprutCAM
    Last Post: 01-22-2014, 03:06 AM
  3. 308 bridgeport discovery z axis overshoot
    By chipsaflying in forum Bridgeport / Hardinge Mills
    Last Post: 04-06-2010, 04:25 PM
  4. G54 X-axis moves??
    By Florida Ted in forum Haas Mills
    Last Post: 03-15-2009, 05:09 AM
