586,121 active members*
3,758 visitors online*
Results 1 to 2 of 2
    Aug 2016
    32
    Conventional milling in 3D milling option
    I'm machining a 3D contour in wood and would like to conventionally mill it as opposed to climb milling but I can't see a way of doing this.
    Is it possible?
    Mar 2017
    24
    Re: Conventional milling in 3D milling option
    Quote Originally Posted by bobhare View Post
    Is it possible?
    You control whether its conventional or climb cutting by the way you select the geometry and what you set in terms of "Tool Side". For example if you choose the outer edge of the top of a cube s that the geometry goes clockwise then set the Tool side to "Left" then you are creating a climb cut. If you reverse the geometry so that it goes counterclockwise and switch the Tool side to Right it then becomes conventional cutting.
  1. Conventional milling
    By bobhare in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-08-2018, 04:18 PM
  2. Climb or conventional milling, which for which?
    By mecanico in forum MetalWork Discussion
    Last Post: 01-15-2015, 11:10 PM
  3. Needed: Offset belt driven milling head for conventional mill
    By Larry Callahan in forum Want To Buy...Need help!
    Last Post: 04-17-2012, 11:20 PM
  4. Thread Milling Climb versus Conventional
    By Geof in forum Haas Mills
    Last Post: 06-27-2011, 04:32 PM
  5. Draw comparison between CNC and conventional lathe amd milling machines
    By fayysl in forum Uncategorised MetalWorking Machines
    Last Post: 12-19-2010, 09:47 PM
