586,612 active members*
3,541 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > MPG Handle problem - Fanuc Series Oi-MB
    May 2014
    4
    Hey Guys,
    I've got a problem with my Fanuc Series Oi-MB MPG Handle's output. When I try to move the X- or Y-axis with the MPG that axis starts to move as expected, but then the Z-axis also moves but it's not even selected. The movement seems to be inconsistent - when I turn the MPG the selected axis moves constant, but then the Z-axis moves interrupted (moves, stops, then moves again)
    When I select only the Z-axis and rotate the MPG, then the Z-axis's movements are constant and no other axis moves along with it. Also when I first start up the machine, the X, Y and Z axes lights are blinking. The same happens when I select the Handle button, after I select an axis - that axis light stays on but the other remaining axes lights still blink - is this normal or should the machine be referenced first ? I can't seem to "Reference Return" any of the axes, it' gives an alarm 090 "Reference Return Incomplete"
    My machine is an old Chiron FZ18W (absolute encoders), it has a few faults which I'm trying to fix and restore it to it's former glory - I would really appreciate any assistance. I'm still a bit of a Fanuc noob, and any help would mean the world to me.
    Thank you.
    Regards,
    PlasmaManZA
    Jul 2010
    118
    Re: MPG Handle problem - Fanuc Series Oi-MB
    this sounds like a cable problem or bad connection inside the mpg unit.
    if this does not fix the problem, you can contact me directly.
    regards
    Norbert
    May 2014
    4
    Hi Norbert,
    Thank you for your assistance - I have just sent you a private message.
    Kind regards,
    PlasmaManZA
  1. Fanuc Series 30i G76 Fine Boring problem
    By JonLewman in forum Fanuc
    Last Post: 06-19-2015, 04:30 PM
  2. Problem on CNC Fanuc controller series 0-MD
    By dlanor in forum Community Club House
    Last Post: 06-11-2013, 07:43 AM
  3. Replies: 26
    Last Post: 06-24-2012, 09:24 PM
  4. GE fanuc Series 21I-M led light problem!
    By tvvism in forum Maintenance DIY Discussion
    Last Post: 10-06-2011, 04:15 PM
  5. Fanuc Series O-M Memory Problem
    By ggundrum in forum Fanuc
    Last Post: 04-15-2011, 04:36 PM
