586,036 active members*
3,558 visitors online*
    Dec 2017
    9
    Power supply bigger than suited for tube?
    Hey all.
    I'm doing a build and will use a cheap 40w tube to get things up and running, when i have all the bugs ironed out i'll get a bigger laser in the range of 60-80w. If i buy an 80w power supply now, will i kill the 40w tube? Just trying not to buy 2 tube and 2 power supplies. Thanks!
    Apr 2018
    Re: Power supply bigger than suited for tube?
    Use Ammeter. Limit current by potentiometer on PSU to 18mA max. Have fun.
    Hello. Yeah, you can use the 80w power supply with the 40w tube. However, you'd need to use a potentiometer to control the voltage level. That will make it suitable for your tube.
    Quote Originally Posted by neo__04 View Post
    Hey all.
    Hello.
  1. New Power supply & Tube now with an issue
    By ozighozt in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-06-2017, 11:47 AM
  2. Rapid Loss of Cutting Power- New Tube, Fairly New Power Supply
    By scrappyjedi in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 02-23-2016, 01:24 AM
  3. 60W co2 tube on 40W power supply?
    By Pairair in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-03-2015, 10:26 PM
  4. Can a bad tube burn up a power supply?
    By rcanada in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-24-2015, 10:27 AM
  5. Is it the tube? Or the power supply?
    By SimonArthur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-20-2008, 06:36 PM
