586,042 active members*
3,668 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Touch plate with Arduino/GRBL and Estlcam
    Sep 2017
    5
    I want my touch plate to work with my Proxon MF70 CNC machine, which is connected to rhe GRBL arduino shield an operated frem Estlcam.
    it works well, but i cannot get the touch plate function to work from Estlcam.
    i connect the two touch plare wires to GND abd SEL pins on the GRBL board, but it is like Estlcam does not "see" this input.
    Anyone knows how i can set this up in Estlcam, i have bere in the section where i can configure inputs, also for "prope" which is what Estlcam calle the touch plate function, but i do not understand how to adress the specific SEL pin on the GRBL board, from this setup section.
    can anybody help?
    Mar 2015
    410
    Re: Touch plate with Arduino/GRBL and Estlcam
    I do not know of it will work, but i found this message on the internet!
    Units has to be millimeters, I could not get the probe to work with Inches.
    The probe should be connected to the A5 input on the arduino.
    I also found this text on the net
    I'm using proximity sensors for my limit switches. If you are having trouble with your Z axis limit switches not working, try swapping the connector over to the Spindle Enable pins... There are two versions of GRBL, one that uses the old z limit and one that swaps it over. I also hooked up a touch probe and created a macro so it measures the z height of your work accurately by finding the height at medium speed, then again at low speed.
    Hope it helps
    Mar 2015
    410
    I just tested this on my machine, probe is connected to A5. You should see the probe position reported.
    Grbl 1.1f ['$' for help]
    <Idle|WPos:0.000,0.000,0.000|Bf:15,127|FS:0,0|WCO: 0.000,0.000,0.000>
    ok
    G38.2 X1 Y1 Z 1 F10
    [PRB:0.227,0.400,0.227:1]
    ok
  1. CNC TB6550 Board Arduino UNO Board Estlcam
    By genesiospinola in forum Stepper Motors / Drives
    Last Post: 10-16-2019, 07:21 PM
  2. Arduino/Uno/Grbl
    By Mckyjns in forum Arduino
    Last Post: 08-22-2017, 03:14 AM
  3. arduino nano with grbl
    By mrsnowie in forum Hobby Discussion
    Last Post: 01-06-2016, 06:25 AM
  4. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
  5. Should I use LinuxCNC or grbl/arduino?
    By CptanPanic in forum LinuxCNC (formerly EMC2)
    Last Post: 04-23-2012, 07:06 PM
