586,111 active members*
3,232 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > rw14 - Spindle will not index on toolchange
    Apr 2007
    I have a rw14 vertical mill, when trying to make a tool change the spindle doesnt know where it is, it will just keep spinning until it error's out
    it will not index so it can put the tool back into the tool carousel clocked correctly
    is there a sensor that went bad, maybe something I can reconfigure, either way this is really putting me in a jam so any help or suggestions would be nice
    thanks, Eric
    Feb 2006
    27
    what controls do you have?
    Feb 2007
    156
    Some use a proximity sensor, others may just use the spindle control to index the thing. Have you called Milltronics?
    Dave
    Schneider Machine
    A force of one
  1. MFG.COM & First Index
    By leggetmachine in forum MetalWork Discussion
    Last Post: 04-02-2009, 06:59 PM
  2. Taig / Digispeed XL spindle index sensor
    By Dfennell in forum Taig Mills / Lathes
    Last Post: 01-02-2007, 06:23 AM
  3. McamX and HAAS TL2 home on toolchange
    By JoelB in forum Mastercam
    Last Post: 12-26-2006, 06:00 PM
  4. Index Cnc Lathe
    By hitachi salty in forum DNC Problems and Solutions
    Last Post: 08-31-2006, 06:54 PM
  5. spindle index, encoder, home/limit switch
    By Wm McNett in forum CNC Machine Related Electronics
    Last Post: 01-13-2006, 01:39 PM
