586,036 active members*
3,457 visitors online*
    Dec 2009
    100
    FC changing material
    Featurecam constantly changes the material from say Aluminum to "Aluminum from [filename]". This throws off the speeds and feeds, of course. I'm sure I'm missing something fundamental, but how can I keep FC from changing the material?
    Thanks.
    Re: FC changing material
    Go to Options -> File Options -> Existing files and set the Feed/Speed to Use the F/S tables from FeatureCAM's F/S Database
    Dec 2009
    100
    Thanks for the reply. Before I do this, will this change the F/S I've already saved for ALUMINUM for each cutting tool?
    No, I think this information is saved with the tool
    Dec 2009
    100
    I'll try that, thanks.
  1. Material Top and Material Bottom
    By wdaehn in forum MadCAM
    Last Post: 12-08-2014, 02:13 PM
  2. Z changing
    By LSI Innovations in forum Tormach Personal CNC Mill
    Last Post: 11-14-2014, 04:20 PM
  3. Changing the WCS
    By asafweis in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-17-2013, 05:35 AM
  4. Help with material purchasing. Should I base my dimensions on the material available?
    By trialanderror in forum Uncategorised MetalWorking Machines
    Last Post: 01-18-2012, 07:10 PM
  5. Changing CS
    By fastolds in forum GibbsCAM
    Last Post: 02-02-2005, 07:31 AM
