586,102 active members*
2,477 visitors online*
    Sep 2017
    Small movements around 0 position
    Hello.
    Preconditions:
    I have a not good AASD-30 servodriver. He is connected to kflop + kanalog.
    In +-10v control mode after power enabling and clicking to Init button the servomotor jerks.
    First video.
    https://youtu.be/zlHt9JOjs0E
    Timeline:
    3s - init
    8s - stop
    13s - init
    25s - stop
    29s - rotation
    31s - rotation
    42s - rotation
    43s - stop
    Right after turning on the power the engine does a jerk for a second, after that it is not on hold (makes a small rotation around zero position)
    The only one way to hold servo motor is to set Pn161 and Pn162 settings to 20 and -20 respectively.
    Screen from documentation
    AASD-30 doc
    But after this settings the servo motor sounds like he dies after I started the program.
    Second video.
    https://youtu.be/TP9wKDMvAlA
    If 10v wires doesn't connected to the one servodriver the servomotor rotates at a speed of about 50 rpm. When they doesn't connected to second servodriver the servomotor rotates with speed about 22 rpm. Speed ​​can vary due to incomprehensible reasons.
    Question:
    I want to know how to set gap around 0v.
    Range -8v to -0.2v, 0.2v to 8v instead of range -10v to 10v
    If it is not possible, could it be fixed in some another way?
    Thanks.
    May 2006
    4045
    Re: 10v control mode. Gap around 0v
    Hi Brodjaga,
    Sorry I don't really understand the issue.
    Are you concerned about analog offsets and drift? That shouldn't be a problem once the servo is enabled. Have you tuned/tested your Axes? Adding deadband into the servodriver is probably a bad idea.
    You might read this wiki article.
    Regards
    TK
    http://dynomotion.com
    Sep 2017
    Tha problem was that the engine made small movements around 0 position when movement signals were not sent (kflop was connected and "initialized").
    The problem was solved by fixing ground connection for all components.
    https://youtu.be/HpuUzENZbfY
    Thanks.
