586,105 active members*
3,297 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Heidenhain iTNC530 Recovery Macro/Sub Prog
    May 2018
    Hello,I am looking to see if there is an M code or sub program that could be ran during a program if there is a break in the program e.g. tool breakage or emergency stop pressed.I need some sort of command to send the machine (3 axis drilling machine) up in Z axis to a safe point and then carry on with the program.Thanks in advance.Scott
    Jun 2015
    4154
    Re: Heidenhain iTNC530 Recovery Macro/Sub Prog
    hi / there is a yellow button on some okuma panels, that allows to perform a specific code when the slide-hold is pressed ( for example right in the middle of a G01 you may send one axis at the +limit and stop after that ); real application example : on request interruption durring hobbing ( sincro SM )
    making this action auto-occure, like when a "tool broked" or when the "emergency button is pressed" requires only a mere mortal with 2-3 extra skills and a golden egg
    perhaps haidenhain has something similar ?
    sometimes i use the " / block skip " to move the tool at a safe position : so i can not trigger this behaviour right in the middle of a cutting movement, but only before or after it occured ( is ok when machining common parts )
    common behaviour to interrupt a feed movement is by using the "slide hold " button : but it is triggered by an operator, and once pressed, it simply freezes the cnc ( at least the linear axis ), but i guess you know that / kindly
    Jul 2010
    118
    read the itnc_530__conversational_programming manual for code M148.
    that might be what you are looking for
    regards
    Dec 2011
    99
    M140 or M148.
  1. HEIDENHAIN iTNC530
    By aliaghaei in forum Drilling- and Milling Machines
    Last Post: 09-10-2018, 07:52 PM
  2. iTNC530 HEIDENHAIN
    By JAMES_2000 in forum Fanuc
    Last Post: 08-23-2018, 11:27 AM
  3. Heidenhain itnc530
    By stanoye in forum HEIDENHAIN -> TNC
    Last Post: 12-05-2016, 09:50 AM
  4. Heidenhain Itnc530
    By alia in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-21-2016, 09:20 AM
  5. Heidenhain iTNC530
    By Jay Roy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-07-2011, 06:31 PM
