586,036 active members*
4,224 visitors online*
Thread: Dental mill?
Results 1 to 12 of 12
    Oct 2015
    24
    Dental mill?
    I am looking for a mill for high precision and I don’t need much of a work envelope (4x4x2”) 3-4 axis work.
    Should I get a dental mill?
    I want sub micron machining
    I will be machining steels and titanium maybe zirconium if i can
    Feb 2007
    4553
    Post Re: Dental mill?
    Kolec94,
    Checkout Minitech, see attached link:
    Minitech Machinery :: Company
    Robert "Fixittt" is a member of the CNCZone and is well versed with Minitech products.
    https://www.cnczone.com/forums/members/fixittt.html
    Quote Originally Posted by kolec94 View Post
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Oct 2015
    24
    Re: Dental mill?
    Quote Originally Posted by jalessi View Post
    Kolec94,
    would that be a better bet then a dental mill?
    Feb 2007
    4553
    Re: Dental mill?
    Are you referring to something like a Roland DWX series mill?
    If so I do not believe the Roland is appropriate for machining steel.
    Jeff...
    Oct 2015
    24
    Re: Dental mill?
    Jeff...
    CNC milling machine - Compac 350 - Table Milling Machine this is the one I was looking at
    Feb 2007
    4553
    Re: Dental mill?
    What is the current price for the Compac 350 today?
    Oct 2015
    24
    Re: Dental mill?
    I don't know I submitted a inquery
    Feb 2007
    4553
    Re: Dental mill?
    Kolec94,
    What is your budget?
    Jeff...
    Oct 2015
    24
    Re: Dental mill?
    Kolec94,
    Jeff...
    under $100k hope for under $50k would anymachine using hsk25 work?
    Feb 2007
    4553
    Re: Dental mill?
    Well you know the spindle alone is about 5K
    https://www.hsspindles.com/product-c...-25e-spindles/
    Feb 2007
    4553
    Re: Dental mill?
    Where are you located, is local support a concern?
    Oct 2015
    24
    Re: Dental mill?
    no as long as its reliable and I can do maintenance if needed in the US
  1. Denver Dental Treatments to Consider
    By Rachel73 in forum Mechanical Calculations/Engineering Design
    Last Post: 10-29-2015, 09:47 AM
  2. need help / dental technician / 5 axis milling
    By flasherbil in forum FeatureCAM CAD/CAM
    Last Post: 06-05-2015, 11:18 AM
  3. Anyone built a dental machine?
    By brian257 in forum Uncategorised MetalWorking Machines
    Last Post: 08-02-2012, 07:44 PM
  4. 3d dental scanner
    By Hugo Shen in forum News Announcements
    Last Post: 03-08-2012, 02:38 AM
  5. Medical/Dental machining
    By otisblackwell in forum Community Club House
    Last Post: 05-14-2008, 05:07 PM
