586,043 active members*
3,828 visitors online*
    72
    roller screw versus ball screw.
    Considering an application like the retrofit of a Bridgeport Knee Mill , is there any advantage to substitute the classical ground ball screw (32mm diameter, 5 mm lead, 13 micro m. / 300mm) by a roller screw like the ones manufactured by SKF ?
    Daniel
    May 2005
    674
    It's similar to the comparison between a needle roller bearing and a ball bearing. Rollers larger contact patches than balls, which equates to higher load capacity. The Nook website shows that a 25mm x 5mm roller screw has an 11000lb dynamic load rating, whereas a 25mm x 5mm ballscrew has a 2000 lb rating.
    But a bigger contact patch means more friction of course, so it'll limit your top speed. Again, just like how the max RPM of a roller bearing is typically much lower than that of a ball bearing.
    Speed won't really matter on a Bridgeport, but neither will load capacity, since the screw is definitely not the weak link on a BP mill. Did you find a pre-owned set of screws? If you're buying new, I'd just stick with ballscrews.
    72
    Thanks for the advise.
    I'll try to get a set of ground ball screws then. Don't trust second hand ones.
  1. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
  2. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  3. acme screw to ball screw question
    By Billw in forum DIY CNC Router Table Machines
    Last Post: 07-18-2005, 06:10 AM
  4. Ball Screw or Lead Screw? Which is Better?
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 07-28-2004, 02:49 PM
  5. Ball Screw and Lead Screw
    Last Post: 11-21-2003, 03:06 PM
