586,352 active members*
3,304 visitors online*
Results 1 to 3 of 3
    Dec 2007
    496
    Saving / Exporting as .dxf
    Does anyone know if this is possible or can be done with solidedge.
    Saving and exporting as a .dxf file
    Jun 2007
    46
    Saving as .dxf
    We save a .psm (Sheet metal) to .dxf. It gives us a 2d view of the part where we then use our waterjet to cut the profile. Once you have the .psm file open, go to "File" - "Save as flat". You then pick the part, then a line (which is used for orientation). You usually HAVE to have a line or it will not accept it. Hope this helps.
    GC
    Feb 2008
    28
    Are you talking about parts or drawings? Solid parts cannot be exported as dxf files. They can only export as solid model files such as step, iges, acis, parasolid, etc. formats.
    Like GCMAN wrote, flats of sheet metal parts can be exported as dxf files, as can drawings. They are done in File>Save As in the case of drawings, and File>Save As Flat in the case of sheet metal parts.
    Basically, it can only export 2D dxf files, not the 3D ones like Autocad supports.
  1. Exporting Text into Sheetcam
    By Millerman in forum SheetCam
    Last Post: 11-10-2010, 04:27 PM
  2. Help needed exporting to DSTV
    By Mac2309 in forum Uncategorised CAM Discussion
    Last Post: 04-30-2008, 10:20 AM
  3. Exporting BBC V22 file to IGS & Alibre
    By tikka308 in forum BobCad-Cam
    Last Post: 12-02-2007, 11:10 PM
  4. SketchUp exporting as DXF then ACE to Gcode
    By IQChallenged in forum G-Code Programing
    Last Post: 09-18-2007, 06:47 PM
  5. Exporting iges files
    By pettyp in forum FeatureCAM CAD/CAM
    Last Post: 08-09-2007, 01:42 PM
