586,052 active members*
4,339 visitors online*
Results 1 to 3 of 3
    Jan 2017
    84
    ATC Spindle How to set them up?
    Hi there
    Could some one direct on how to set up an ATC Spindle, I am trying to Install a CC spindle, which is a copy of HSD,
    Just a general Guide I need,
    particularly on its sensors, do I need to address them in my ATC VB Scripts?
    regards
    jhonansaro
    35538
    Re: ATC Spindle How to set them up?
    Usually, yes.
    What sensors does it have?
    You want to at least check the sensor that tells you the tool has been picked up.
    Jan 2017
    84
    Hi Gerry
    thanks for the reply
    this is what i thought to be, do you know what is the Script code that address them?
    The sensors are for:
    1: Chuck Closed
    2: Chuck open
    3: Running Spindle
    Let's say that i have dedicated Input4, Input5, and Input6 for my sensors.
    do i need to address them in my M6 Codes, If yes please tell just the few lines needed for this matter.
    Could it be done with following codes:
    If IsActive(input4) Then
    Code "M5" Trying to stop everything, If there is better way please let me know
    End if
    Exit the Sub
    also could it be like a Limit switch or Estop, that I do not need to address them and they just stop everything when they are turned on?
    Regards
    jhonansaro
  1. Replies: 3
    Last Post: 10-19-2018, 05:12 PM
  2. Replies: 6
    Last Post: 03-20-2017, 09:30 PM
  3. Replies: 39
    Last Post: 01-09-2017, 06:26 AM
  4. Replies: 5
    Last Post: 07-19-2013, 05:16 AM
  5. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
