586,068 active members*
4,417 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan Lynx 220 LMS-C - "Y" Direction adjustment procedure
    Sep 2008
    87
    Lathe is a Doosan Lynx 220 LMS-C Sub Spindle and C axis. No Y - that would have been too easy.
    Does anyone have the recommended procedure for adjusting the "Y Axis" on this lathe? The Y is off by .003".
    I would like to shim the turret up to get it back on center.
    Any help appreciated. Thanks.
    Feb 2013
    788
    Re: Doosan Lynx 220 LMS-C - "Y" Direction adjustment procedure
    The turret was crashed with the curvic locked. This caused the rotateable face, which was locked to the stationary chassis via the 2 or 3 piece curvic, to force the curvic to move within the play of the heads of the socket head cap screws that hold it. If the alignment pins were still in, then they are damaged as well.
    If the alignment pins were not in, then this is an adjustment. If they were in, then this is a repair.
    Please do not "shim" the turret, as the problem is not that you are out in Y...the problem is that you have a misalignment of a rotation that appears as if it is out in Y (and in X, as well)
    Use the alignment instructions that are in the service manual for a puma 240, located in the thread that has all my manuals.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Feb 2013
    788
    Sep 2008
    87
    Wow, that was quick thanks!
  1. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  2. Doosan Puma TT1800SY - APC "Alarm" on start up
    By Saranac in forum Daewoo/Doosan
    Last Post: 06-28-2015, 03:07 AM
  3. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
