586,356 active members*
2,914 visitors online*
    Oct 2015
    215
    Fanuc OM-C Probe macro
    I'm trying to write some simple macro to set Z-tool offset of a Renishaw ts20 probe. I got the basics so that I write the current Z machine position to the current tool offset when the Z stops off the high speed skip signal.
    Then I started reading some about macros and I see that when going with a spindle probe from Renishaw many are recommending the inspection plus macros from Renishaw to go with it. This covers tool probing and all possible probe setups that I can think of when reading through the manual. It also has some nice routines for probing out offsets in the probe tips and so on.. Seems WAY overkill for a home setup like mine :P
    Should I just give up writing my own macros and start saving for inspection plus? Is there anyone that has made their own basic set of macros that has shared them online or is doing it from scratch the only option?
    Feb 2006
    1792
    Re: Fanuc OM-C Probe macro
    This book has a chapter on probing
    https://www.amazon.com/dp/0071713328
    You may write your own routines.
    Oct 2015
    215
    I got it sorted. Ended up with macros from renishaw since they where so nice and integrated into fusion 360 ^^
    I do have a little follow up regarding connecting this to my machine but maybe this isn't the proper thread for that.. I'll try I was planning on using a MI8 interface on the high speed skip input (this is 5V with 3.3k load resistor). Then my probe arrived with a SCM module instead and since my interface has not arrived yet I was wondering if I could do some testing with the signal condition module directly to the regular skip input. This is 24V but I can't find any info about the size of the load resistor on the fanuc board. Does anyone know? Maybe I should just wait a few days until the MI8 arrives ^^
    Oct 2015
    215
    Sketched up a pull up resistor connection of the probe using a 10k I had lying around. This should give me a inverted input so that the NC probe is giving a zero at the input when it's not touching and a 1 when it's touching and with a current of 2.4mA. I might use two 10k in paralell to double the current. I've never done this before so I'm prepared to see some magic smoke lol
  1. Probe Macro 9023
    By mottoman in forum Haas Mills
    Last Post: 10-11-2013, 06:57 PM
  2. Macro for reinshaw probe
    By Mazacam junkie in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-15-2013, 03:03 AM
  3. Need probe macro for M&H Infared Probe 25.41-HDR
    By nikolaiownz in forum Fanuc
    Last Post: 02-11-2012, 03:10 AM
  4. probe macro
    By damon1313 in forum Digitizing and Laser Digitizing
    Last Post: 04-22-2008, 09:21 PM
  5. Macro for a probe signal
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-11-2006, 07:04 PM
