586,062 active members*
4,713 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > Is There Any Need For A Quill Lock On A CNC'd Quill?
Results 1 to 7 of 7
    Sep 2017
    21
    If so, why?
    Thanks in advance.
    15362
    Re: Is There Any Need For A Quill Lock On A CNC'd Quill?
    Quote Originally Posted by Overtorque View Post
    If so, why?
    Thanks in advance.
    You did not say what kind of machine this is on
    If it is a quality machine, then no you would not need it, you would need to block the hole though, any chips getting will seize up the quill
    For any cheap import machines, you may need it to take up the slop in the quill, as most have too much clearance between the quill and the housing, removing the handle would be a good idea, if you have it to tight that could be a problem as well
    Mactec54
    Sep 2017
    21
    Thanks for your reply.
    It's a Manford Super Precision knee mill (Taiwan), converted to CNC. They claim TIR at the spindle taper is <.00012, so it should be a tight machine.
    15362
    The spindle run out spec, has nothing to do with the quill and Housing clearance, but these machines should be no as loose as some, I would not take it out, just remove the locking handle
    Looks like what you have is the same machine as the Acer there are many that are just rebranded
    Mactec54
    Sep 2017
    21
    Thanks for your reply, once again.
    I was under the impression that the spindle runs in the quill, so wouldn't a tight spindle = a tight quill?
    Keep in mind that the quill is held in place (in part) by the cnc quill drive kit.
    I appreciate your replies, this is new ground for me.
    The manufacturer (Manford) took out the quill lock when installing the quill drive, so what I'm specifically asking is;
    Do I need to purchase and install one?
    15362
    Not really what you first asked, if the retro fitter removed it then there would be no need for it, they are protecting the quill by removing it, as if it go locked up to tight it would cause damage, I would make sure the hole is blocked off, or chips will get in there and cause more damage than if it still had the quill lock in place
    The spindle runs in the quill yes, but the quill runs in the Head main housing, this is were the quill has to be a good fit, the lock is not related to the spindle in any way, the lock is related only to the Quill and main Head Housing
    Mactec54
    Sep 2017
    21
    Thank you, once again, for your answer.
  1. Quill Movement
    By richwinejr in forum Bridgeport / Hardinge Mills
    Last Post: 01-07-2013, 05:04 PM
  2. Quill bearings, etc.
    By jason_b in forum Charter Oak Automation Support Forum
    Last Post: 10-20-2012, 11:36 PM
  3. RF-45 Quill DRO
    By Speed57 in forum Benchtop Machines
    Last Post: 10-07-2012, 03:17 AM
  4. DRO on the Quill
    By ajclay in forum Bridgeport / Hardinge Mills
    Last Post: 04-12-2012, 12:48 AM
  5. Tightening My Quill
    By Arich0908 in forum Benchtop Machines
    Last Post: 06-08-2010, 03:31 AM
