586,070 active members*
3,635 visitors online*
    Oct 2014
    15
    Colchester 2000L CNC
    Hi Everybody,
    I have just got an old Colchester 2000L CNC with a Fanuc OT A control. I can power it up, jog and MPG the axis no problem. I have pushed (or it seems like) every button, in every combination I can think of but I'm unable to get the lathe to "Home". I don't know if there is a fault or I'm pushing the correct buttons in the correct sequence.
    Can someone please list the procedure for me? IE from the first operation of turning it on, guard open - shut etc.
    Thanks for any help.
    RHK
    May 2016
    526
    Quote Originally Posted by Rathousekid View Post
    Hi Everybody,
    RHK
    The machine doesn't home it is set through parameters
    What does parameter 20 say
    Oct 2014
    15
    Re: Colchester 2000L CNC
    Hi, Thanks for your response.
    Parameter 0020 is just zeros. Because there is a "Zero return" position on one of the rotary switches, I assumed it needed to be homed.
    Any help gratefully received.
    RHK
  1. Colchester 2000L
    By bertcnc in forum Colchester Tornado lathes
    Last Post: 06-25-2020, 07:40 AM
  2. colchester cnc 2000l parameter
    By kabdelwahid in forum Colchester Tornado lathes
    Last Post: 08-05-2016, 04:59 PM
  3. Colchester 2000L APC 310 and 320 Alarm
    By rjhzxc in forum Colchester Tornado lathes
    Last Post: 04-23-2014, 02:38 PM
  4. Colchester 2000L Fanuc OT
    By davee1987 in forum Uncategorised MetalWorking Machines
    Last Post: 05-18-2013, 10:26 PM
  5. Need Parameters For Colchester 2000L CNC
    By Hakam in forum Colchester Tornado lathes
    Last Post: 10-27-2012, 02:46 PM
