Carbide Cutters For Woodturning
This is carbide cutters for woodturning cnc lathe. The excellent carbide (tungsten) is chosen as the raw material of blade, because its durability is more than 20 times that of the white steel, and also more than 10 times of the high speed steel. The cutters is ideal for roughing or finishing jobs on wood.
Full carbide cutters for woodturning set include:
Blade – 1 piece
Cutter Bar – 1 piece
Wrench
Screws & gaskets
Carbide Cutters For Woodturning Specification
Cutter Bar: 40Cr Steel, size 20*20*150mm or 25*25*150mm
Blade: high quality solid carbide (tungsten)
Blade length: 40mm
Cutting angle: 17 degree
Blade tip radius: 0.75mm / 1.0mm / 1.5mm
Blade thickness: 13mm
Blade Hardness: 92.6 HRC
Learn More, pls click? https://www.eaglecnctec.com/products...ing-tools.html
Enquire now if any interest! Email: [email protected]
