586,296 active members*
4,130 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach 1100M Info Possible Series 4!
Page 2 of 8 1234
Results 21 to 40 of 143
  1. #21
    Mar 2009
    1863
    Quote Originally Posted by SCzEngrgGroup View Post
    Of course, you coulda had a Novakon mill with all those features, plus 500 IPM rapids with AC servos, 4+ years ago...
    Regards,
    Ray L.
    Ray, if you’re such an advocate for Novakon milling machines, what the heck are you doing here?
  2. #22
    Jul 2004
    1424
    Re: Tormach 1100M Info Possible Series 4!
    Quote Originally Posted by Steve Seebold View Post
    here we go again...
    And it has been so pleasant for the past year or so... ever since the Moderators brought out the ban hammer.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
  3. #23
    Aug 2014
    28
    ...and replaced with FAR worse problems...
    And someone please tell me the great value of rigid tapping? A T/C holder can do very nearly the same job, and is more than adequate for all but a few corner case applications (like tapping to the very bottom of a blind hole), and those few cases can be easily handled with thread milling, which gives you a LOT more flexibility, albeit at lower speed. I have a set of six home-made T/C heads I use for all my tapping.
    Regards,
    Ray L.
    I have been pondering this myself. If it’s a standard feature then it has value, but if they are charging an additional $500+ for the feature I’m going to pass. To me the Tormach is a good gateway machine to bigger things. It would be insane in my opinion to spend close to mini mill or TM-1P money on an upgraded Tormach. Time will tell though.
    - - - Updated - - -
    The 1100M might have a lot of upgrades over my machine, but ya know what makes my 1100 Series II running Mach III a better machine than an 1100M?
    MINE IS PAID FOR.
    That’s awesome! No real reason to update!
    - - - Updated - - -
    Quote Originally Posted by Advil View Post
    The biggest advantages to a servo drive motor for me would be larger slower drilling, larger slower tapping period rigid or not and slower feeds and speeds with large end mills. Handy for titanium or stainless. Not to mention being able to run a good sized arbor slitting saw at the proper stupidly slow RPM with plenty of torque.
    I've idly perused a few catalogs of large servo motors that could replace my 770 drive... but if you already have a working machine it's a silly expense and a LOT of work.
    Now on a bigger more rigid 1100... it's going to come down to cost.
    I agree!
  4. #24
    Nov 2012
    591
    I do a lot of M2.5 threaded hole, and each of them has to be hand tapped. M2.5 with a compression holder is, I'm told, "not advised."
    With rigid tapping, you have the hardware drive down Z exactly in line with the speed of the spindle. If you have an encoder on the spindle, this is technically simple.
    However, more interesting, is the use of BLDC motors in the current lower-end mills. Because of the way BLDC works, the controller knows at all times where the motor is (within a few degrees) because it needs this knowledge to properly drive the motor phases. Thus, this knowledge that it already has, could be extracted and used, using basically software only.
    Now, would this be the first time a company has considered charging for a purely software upgrade? No.
    (I hear Haas charges thousands both for the ability to use all the RAM that's already in the controller, for actual G-code programs, and for turning on the bit of the software that looks more than one move ahead to plan the toolpath. I would, too, if I were like them, and could get away with it!)
  5. #25
    673
    Regards,
    Ray L.
    I think you missed my point - I like the enclosure, panel in the enclosure, not having the control box in the cutting area etc.... Just better thought out in some ways. Not trying to say it was a great machine for whatever reasons, just that it had some features that were better, as to all the pro level machines. It wouldn't take a ton more money to have a decent stand/enclosure/way covers.
  6. #26
    Jul 2007
    1602
    Quote Originally Posted by jwatte View Post
    Get an auto-reversing tapping head for the small taps. Don Clements has been using a Procunier for years with great success.
    bob
  7. #27
    Feb 2008
    644
    One advantage of rigid tapping is that you can do peck tapping, which is not possible with a tapping head
  8. #28
    Feb 2006
    7063
    Quote Originally Posted by PCW_MESA View Post
    It is entirely possible with a T/C tapping head, not a reversing one. Though with a VFD spindle, and no encoder, controlling depth is tricky.
    I actually have a variety of tapping heads - used them all. I have a brand-X Chinese, a TapMatic, a Procunier, all reversing heads. Then I have my 7 home-made T/C heads. Since making the T/C heads, I have no use for the others. The Chinese, TapMatic and Procunier are all quite different, each with it's own plusses and minuses, and quirks. The Procunier is, in most respects, the best of the bunch but also the most expensive. The friction clutch is FAR more aesthetically pleasing than the dog clutches on the other two. But, for day-to-day use, the T/C heads are, IMHO, by far the best all-around solution.
    Regards,
    Ray L.
  9. #29
    May 2016
    316
    Drifting off-topic a bit...
    Rigid tapping - I get a little more Z clearance by just using a short collet, although Ray's home-made T/C heads are pretty darn short. Also - for my particular non-Tormach mill - I am lacking in very low RPM torque due to my pulley ratio. Peck tapping permits me to tap up to 1/2-13 in steel fairly deep, whereas it'd stall if I tried to tap much over 3/4" deep in one shot.
    Yes, I could threadmill, but I haven't invested in one of those yet. Rigid tapping isn't necessary, but it opens up a few options that a non-synchronized spindle/head arrangement can't quite manage. And if I ever switch to a BT30 spindle the encoder is already in place for spindle homing.
  10. #30
    Aug 2014
    28
    The latest rumor I heard was June 4th for the announcement. Im interested in what they will be doing!
  11. #31
    May 2007
    1026
    For what it’s worth, I’ve been tapping 4-40 holes in 6061 with the ER-16 TC holder for a while without any difficulties. I’m using a Balax form tap, going up to .250” deep. M2.5 is pretty close in size.
  12. #32
    Nov 2012
    591
    That's good to know, thanks!
  13. #33
    Jun 2012
    311
    Quote Originally Posted by sansbury View Post
    I've tapped 4-40 in 416 SS and O2 with the ER-20 TC. I use a #42 drill (.0935) after I broke a tap with the standard #43.
  14. #34
    Aug 2014
    28
    Edited due to no value in my post.
  15. #35
    Nov 2017
    4
    I called Tormach this morning with a couple of technical questions related to my planned purchase of a 1100 in the next couple of months.Talked to a nice lady who got me the answers I needed, and then I queried her about the "rumors" of a pending upgrade to the 1100, IE: 1100M.
    She was very non committed in her response, and suggested I subscribe to the Tormach blog where the "latest announcements will be posted.
    When I mentioned that it seemed like they want no leaks from corporate before the official announcement (if any) she laughed and said they are trying their best.
    I for one will not order an 1100 untill I see what is in the offfing as far as upgrades etc. I don't know whether they wan't to get rid of the old models first but you would think that they would be promoting the new and improved version as soon as possible.
    It may not be a Hass but is still a chunk of change to lay out and find out a month later that you are outdated.
    Just one mans opinion.
    Greg
  16. #36
    Aug 2014
    28
    I agree and this is where I am currently at and the changes look well worth the wait as long as it is reasonable.
  17. #37
    Nov 2016
    151
    I second this.
  18. #38
    Apr 2013
    1788
    From Tormach's latest email:
    Tormach’s commitment to research and development, engineering innovation, and CNC machining support remains as the cornerstone of the company. We relentlessly invest in new product development and product expansions, as well as differentiated niche products and standard commodity products.
    We have a knowledgeable and talented team of engineers and machinists working on breakthrough product ideas – just for you. We're not afraid to move into new manufacturing product categories if we believe there's value and contributions we can make for you.
    As part of all this, stay tuned for a big announcement next week!
  19. #39
    Oct 2010
    670
    And we wait...... 9:20am - 6/4 and still no news.....
    The Body Armor Dude - Andrew
  20. #40
    Aug 2014
    28
    Yeah I am excited to see what they announce.
Page 2 of 8 1234
  1. I need Info On The Tormach Machines
    By usarty1 in forum Tormach Personal CNC Mill
    Last Post: 03-24-2024, 03:47 PM
  2. Anilam 1100M
    By jthornton in forum Bridgeport / Hardinge Mills
    Last Post: 03-15-2023, 02:58 PM
  3. Tormach PCNC 1100 ATC info - want to do it myself.
    By SoCalPlaneDoc in forum Tormach Personal CNC Mill
    Last Post: 03-05-2016, 02:04 PM
  4. Replies: 7
    Last Post: 03-06-2015, 01:41 AM
  5. ANILAM 1100M
    By blakey235 in forum Controller & Computer Solutions
    Last Post: 08-03-2014, 12:01 PM
