586,108 active members*
2,971 visitors online*
IndustryArena Forum > CAM Software > Surfcam > I'm new, Please help with lots of questions
    Apr 2007
    I only have VERY limited knowledge of Surfcam and I have to do this for my project. Please take a look at the picture:
    I want to do the contour but the tool path is wrong. The ball mill is going in from the bottom instead of the top. I tried to change the coordinates but it didn't help. How do I change it so it will start lead in from the top?
    Later, I have to turn the piece up side down to do the pocket. How do I tell the program to pause so I can turn it up side down? How do I tell the program that I have turned it 180 degrees and start milling from the opposite?
    I'm new at this and I know these are simple stuffs but I'm lost. Thank you very much in advance.
    Aug 2006
    259
    all has to do with your coordinate system and where your XYZ zero is.
    I normally do everything in construction view (cview) with a normal vertical mill, x axis goes left to right, y axis goes back and forth, z axis is up and down. you would want z positive to be pointed up.. here's a test part I made, notice the location of the xyz0 above the part, I actually made the top far right corner of my stock my zero point (which isn't normal operation, normally I would select a finished face of the part to be Z zero, but as it was just a test piece, I didn't worry about it any). To flip the part over, I would just create another xyz0 on the bottom side and run a new setup operation, which would create a separate program.
    Apr 2007
    I didn't know about the set up and already did the part in Solidworks with the coordinates shown. Is there a way to change that in Surfcam or I have to go back to Solidworks and change over there?
    Aug 2006
    259
    yes you can create it in surfcam, click the cview button and create a new cview. multiple ways to do it. search the help files also, they give more in depth knowledge about it.
    Mar 2007
    4
    On your stock setup your material thickness (corner 2 Z axis) needs to be a negative number.
  1. Lots of CNC questions (help a noob!)
    By *o* in forum DIY CNC Router Table Machines
    Last Post: 03-05-2009, 11:52 PM
  2. missy here: lots of questions about vinyl cutters.. HELP!!
    By MissyTallBoots in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 09-08-2007, 01:59 AM
  3. Lots of Newbie Questions !
    By diarmaid in forum Casting Metals
    Last Post: 08-23-2006, 11:22 PM
  4. Haas Lathe Questions - Lots
    By 1ctoolfool in forum Haas Mills
    Last Post: 08-14-2006, 12:47 AM
  5. What to do with lots of little motors?
    By Evodyne in forum Community Club House
    Last Post: 02-19-2006, 01:26 AM
